Clarion CV737 trunk mounted cd changer
Old Feb 8, 2003 | 01:03 PM
jack63ss's Avatar
I just picked up my 2000 Maxima GXE today. One of the things noone at the 3rd party (non-Nissan) dealer I bought it from could figure out was how to make the CD changer work. I have the standard "FM-AM radio with Cassette Player", but there is a Clarion CV737 mounted in the trunk. Can someone explain how to control it ? Is there supposed to be a seperate control until or can I run it through the radio somehow ?
Jack
Old Feb 8, 2003 | 06:28 PM
kramerica72's Avatar
Re: Clarion CV737 trunk mounted cd changer
Jack
Does your radio have the CD Changer button on it?
Old Feb 9, 2003 | 11:34 AM
jack63ss's Avatar
My radio does not have a changer button. Looks like the stock non-cd am/fm/cassette radio. Could it need an external controller ?
Old Feb 10, 2003 | 04:43 PM
KsuMax's Avatar
Cheesing away...
I have a 12 disc cd changer in my trunk and it plays through the radio. But I also have a seperate changer output device up front.
Old Feb 10, 2003 | 06:55 PM
Bgohan's Avatar
Jack
You are likely missing the CD remote. Check the CD changer part number to see if it is an RF unit.
Old Feb 22, 2003 | 01:23 AM
Bgohan's Avatar
Jack
The Clarion CV 737 is NOT an RF-type cd changer.
A: I suspect someone changed out the original Radio head unit that had a CD changer option with the one that is currently installed.
b: There is no way to control this cd changer using head unit without the cd changer option.
But, if the seperate CD changer commander was installed under radio, you could. If it was there, you would know it. It would be installed in the pocket under radio. Do you have a pocket without a cover under the radio as well as a storage pocket with a flip cover above ashtray?
You could take out the radio and look at back to see if a cd changer cable is installed. It is a thick black cable routed out the back and to the right of console back to trunk.
Old Feb 22, 2003 | 03:47 PM
jack63ss's Avatar
Re: Re: Clarion CV737 trunk mounted cd changer
Thanks. I didn't think it was RF. My Nissan dealer suggested the same thing you did, so I'll take a look behind the radio and see what I find. So my next question is, what is the easiest way to get the radio out ?
I haven't decided yet if I am going to buy a Commander ($65) or a 3rd party AM/FM/Cassette or CD with Changer Control and a Remote ($150-200 at least).
Old Feb 23, 2003 | 12:34 AM
Bgohan's Avatar
Re: Re: Re: Clarion CV737 trunk mounted cd changer
Go here to see how to remove radio:
http://www.sju.edu/~jz102751/car_audio/
Old Feb 25, 2003 | 01:31 AM
Bgohan's Avatar
Look on E-Bay for the Bose head unit with cd/cassette/ changer.
People rip out good Bose units to upgrade stereos all the time. They often go for less than $100.
Old Feb 25, 2003 | 06:06 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Re: Re: Re: Clarion CV737 trunk mounted cd changer
....then hell also need the rest of the Bose system to go along with it.
--Don
Old Feb 27, 2003 | 06:11 AM
dvpatel99se's Avatar
Re: Re: Re: Re: Re: Clarion CV737 trunk mounted cd changer
You can buy the Non-Bose SE head unit (AM/FM/Cassette/CD) which comes with an inbuilt controller and make all that work. The CV-737 is a CD changer that works with both the Bose and the non-bose. You can buy a separate controller from the dealer too but that might not be economical as for the money that you will spend on the controller you might get a relatively new stereo which cassette and cd.
If you do have the Bose system, then you will need the Bose unit. Hope that the dude who replaced the radio did not rip apart the control cable.
--Don
Old Feb 28, 2003 | 10:15 AM
jack63ss's Avatar
I did take a look on E-bay for a factory radio and did see a couple with changers. Given I have the stock 4 speaker factory speakers, is there anything special about the Bose unit or can I just drop it in ? I plan on a speaker upgrade at some point, but cd changer is first. Also, does anyone know what "year and model" radios will interchange with a 2000 Maxima ? For example, is the Altima Bose the same (look it but ..) ?
Old Feb 28, 2003 | 10:41 AM
Jack,
I don't think the GXEs ever came with the BOSE but I could be wrong. If your car did not come with the BOSE you can't just slap that puppy on. You will have to change the entire setup including the speakers. In 2000, they changed the system so that it ran off of 1 amp in the trunk. So, if you have an amp in the trunk, chances are that you had a bose. If not, then you might just want to look for AM/FM/Cassette/CD (Non-Bose) from 2000 - 2002 Maximas.
Old Sep 29, 2011 | 06:12 PM
hungy82's Avatar
How to install cv737?
Hey there, I just purchased a clarion cv737 from ebay to install in my 00 maxima, it came with the wire harness, basically the whole package, question is, how do I install this thing, and where at in the trunk do I install it? If anybody has any pics of where its located in the trunk or has done an install like this, please let me know. Thanks again!
Old Oct 5, 2011 | 10:56 AM
hungy82's Avatar
just a courtesy bump, anybody have any clues or ideas of how I should install this puppy? thanks
Old Oct 5, 2011 | 01:47 PM
ampire's Avatar
I am guessing the (2000?) factory service manual will have the answer you seek, since that cd changer was a factory option on some maximas.
I wish I could be more help, I recommend posting in the 5th gen forum you will get more people looking there.
Old Dec 11, 2023 | 11:06 AM
simplytimby2's Avatar
Jack
Trunk mounted Clarion CV737 cd changer, will this play through a standard am-fm radio on a 2003 Nissan Maxima SE?
Old Dec 12, 2023 | 07:38 AM
Prophecy99's Avatar
can I ask why are you using CDs?
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
