Problem.....
Old Feb 18, 2003 | 08:01 PM
chigga's Avatar
Problem.....
i jus got the alpine 7893 put in with boston pro 6.5's and rm 6's. sometimes when im playin my music, it gets staticky and the words sound garbled. i brought it to tweeter but of course it played fine when i asked dude what the prob could be. could anyone help a brotha out....
Old Feb 19, 2003 | 09:15 AM
erty67's Avatar
Decal Specialist
Re: Problem.....
I'd have to hear it to have a better idea, but try this...
Sounds like you get that sound when playing "your" music, so I'll assume that means playing a CD. Next time it starts, switch to the tuner and see if happens with the radio playing. If it stops, then you know it's related to the CD section of the deck and your speakers are most likely ok. If it happens w/ both CD and radio, maybe try connecting one set of speakers at a time. Disconnect the rears for a few days, then try the fronts. If you still have the old speakers or you have a set laying around, disconnect all the new speakers and connect the old one with some speaker wire. Just leave them on the passenger floor for a few days and see if it happens with them. This would also eliminate the new speakers from the equation and you'll be able to see if it's the deck or not(I know it won't sound to pretty, but it will help prove something). It could be many things, so try try one step at a time until you can narrow it down. Good luck.
Old Feb 19, 2003 | 09:28 AM
erty67's Avatar
Decal Specialist
Another thought...
You can connect a set of speakers for a walkman to the RCA outputs of the deck. To do this, you will need an adapter to convert thr RCAs to a headphone plug(radio shack, like $3). Doing this, you could leave the adapter set up and play your system as-is. When it starts to mess the sound up, plug in the headphone speaks and see it happens....Not my personal preferred way to do it, but it may help.
Old Feb 19, 2003 | 03:17 PM
chigga's Avatar
thanx man im gonna try the 1st one u said.....
Old Feb 19, 2003 | 07:32 PM
crazyravr's Avatar
Im not too sure if I know what you mean but.... do the speakers distort when you are playing music very loud ? If thats the case then your speakers are underpowered and are distorting. A simple solution would be in that case to get an amp.
Old Feb 19, 2003 | 07:35 PM
chigga's Avatar
ahhh that was gonna be my next question if they are underpowered cuz it is when im playin them loud. only problem is is that i don't wanna get a amp now cuz thats my next year project, to get the whole trunk done up. damn decisions decisions.....
Old Feb 19, 2003 | 07:53 PM
crazyravr's Avatar
There is your problem. There is no fix for this but an amp.
Old Feb 19, 2003 | 07:54 PM
chigga's Avatar
damn man why u tell me that. will ampin my speakers add more bass to em too????
Old Feb 19, 2003 | 08:15 PM
erty67's Avatar
Decal Specialist
amping your speakers will give them more fill, so it will seem bassier(is that a word? ) You should be able to play them pretty loud without an amp. I'm guessing on this, but you should be able to reach about 2/3-3/4 of the maximum volume setting before distorting. Try setting you bass control lower(0 or around the middle) and make sure your loudness control is off. What exact name and model of speakers do you have?
Old Feb 19, 2003 | 08:17 PM
chigga's Avatar
boston pro 6.5 components and boston rm6's in the rear......
Old Feb 19, 2003 | 08:31 PM
erty67's Avatar
Decal Specialist
crazyravr has a good point. both of those speakers have high wattage requirements. Even with that 60x4 deck(actually about 20-25w RMS), you are barely pushing those speakers. An amp may be the way to go. I noticed the pro 6.5s handle up to 400W, but they are need a minimum of 20w. You are just barely making that with your deck.
Old Feb 19, 2003 | 08:33 PM
chigga's Avatar
yeah cuz the hu is givin out 27 watts rms. maybe that is the prob. maybe i might jus get them amps put in a temporary setup....
Old Feb 19, 2003 | 08:38 PM
erty67's Avatar
Decal Specialist
how loud are you turning up your volume to get that distortion? How loud is it actually at that level?
Old Feb 19, 2003 | 08:40 PM
chigga's Avatar
i only put it up to 20 at the most and it goes to 35. hows that jl 300*4 i heard good things??
Old Feb 19, 2003 | 08:50 PM
erty67's Avatar
Decal Specialist
I don't know much about the JL amps, but I also have heard good things.
Old Feb 19, 2003 | 08:52 PM
chigga's Avatar
koo thanx for tha help erty i owe u one.....
Old Feb 19, 2003 | 09:05 PM
erty67's Avatar
Decal Specialist
You're welcome Personally, i would hook up another set of speakers, just to see if I have the same results. If you have a set laying around(preferably lower power handling), try them to see if the deck can push them ok. Also, I noticed you live in MA. I'm not sure if you are close to RI, but there is a meet on 3-2-03 in RI if you're interested. The 2-9-03 one was fun. We had about 15 total maximas and about 10-12 of us for lunch.
http://forums.maxima.org/showthread....hreadid=188568
Old Feb 19, 2003 | 09:07 PM
chigga's Avatar
hmmm ri is close but i wanted to have my rims and my car dropped b4 i went to a meet. yall havin one in april?? i might come thru, lemme know....
Old Feb 19, 2003 | 11:07 PM
jmax
You might also want to look into sound deadening the doors where the speakers are mounted. Can make a world of difference. If the door is rattling or the back wave of the speakers leaking out into the car, you will have cancellation and distortion.
Blake2000
May 3, 2015 08:12 PM
01MAXIBOY
Apr 2, 2013 07:26 PM
str8max
39
Nov 18, 2010 12:38 PM
speed3000gt
Jul 7, 2008 06:28 PM
