Bose HU is removed, Kenwood HU is installed
Old Jul 20, 2006 | 09:43 PM
  #121
YoMax's Avatar
I've just connected Apline HU through Metra 70-7551.
I connected RCA plugs and red, yellow, black, blue, and orange wires. First, I did not hear any sound at all. Then I realized that I need to connect blue with stripe wire in order to turn on the bose amplifier. Now the HU works. However every time when I change tracks or radio stations there is a loud click. Does anybody have an idea how to fix this?
Old Jul 20, 2006 | 10:23 PM
  #122
JEXTEL's Avatar
What kind of click? some radio's have them preinstalled
But from what im reading it maybe the install....
Old Jul 20, 2006 | 10:47 PM
  #123
JEXTEL's Avatar
does walmart sale the Scosche OEA-4?
Old Jul 20, 2006 | 10:50 PM
  #124
YoMax's Avatar
It is kind of popping sound. It is definitely not preinstalled.
I guees it is a grounding issue. I connected the black (ground) wire from the HU to the black wire from 70-7551. Should I connect it directly to some metal surface in the car?
Old Jul 21, 2006 | 05:17 AM
  #125
djfrestyl's Avatar
Suspension Yoda
Yes, directly to metal.
Old Jul 21, 2006 | 10:29 AM
  #126
YoMax's Avatar
Hi again. OK, I grounded the HU directly to metal but I still have the same pops when changing tracks. Do you have any other suggestions? BTW, there is a black/white wire coming from Metra 70-7551 called "Amp Ground". Should I connect this wire to anything?
Old Jul 21, 2006 | 10:31 AM
  #127
djfrestyl's Avatar
Suspension Yoda
Amp ground need not be connected to anything, but tape/cap it off to make sure it's not touching anything.
Old Jul 23, 2006 | 10:32 PM
  #128
JEXTEL's Avatar
Quick question where do the Illumination, Dimmer, and Power Antenna Wires get connected on the Aftermarket HU? (4th)
Old Jul 24, 2006 | 04:28 AM
  #129
djfrestyl's Avatar
Suspension Yoda
Illumination (+) Gets connected to the Orange/White. Don't worry about the Orange/Black (Negative dimmer), just tape it off. Power antenna goes to power antenna (solid blue -> solid blue)
Old Jul 25, 2006 | 09:29 AM
  #130
JEXTEL's Avatar
My HU dont have any where for the Illumination, Dimmer, and pwr ant. to go..
Old Jul 25, 2006 | 09:54 AM
  #131
djfrestyl's Avatar
Suspension Yoda
Did you get a harness?
Old Jul 25, 2006 | 10:49 AM
  #132
JEXTEL's Avatar
no Im broke and can't order one until next pay, but need some tunes now my CD player on the bose dont work..
Old Jul 25, 2006 | 03:04 PM
  #133
yukster's Avatar
I guess I will post this here, since it hasn't been posted yet, and the FAQ was unclear.
For good AM/FM reception in 5th gen Maximas, be sure to connect your power antenna leads. The 5th gen as an built in antenna booster, and the power antenna leads connected, you will get very bad reception on your aftermarket HU.
Old Jul 25, 2006 | 03:18 PM
  #134
djfrestyl's Avatar
Suspension Yoda
This has been posted many many times all over this forum.
Old Jul 25, 2006 | 10:53 PM
  #135
Dan5.5's Avatar
Anybody have a bose headunit for a 2002 maxima lying around that they wanna sell? Must be fully functioning
Old Jul 25, 2006 | 11:13 PM
  #136
Pearl96Max's Avatar
I tend to get a bit irritable
Post it in the classifieds. This is not the place.
Old Jul 29, 2006 | 02:00 PM
  #137
JEXTEL's Avatar
Sorry to crap again im having no luck installing my HU I can find the right diagram, all the ones i found dont work....
Im currently not using a convert....
Old Jul 29, 2006 | 06:18 PM
  #138
JEXTEL's Avatar
After tryim all day I do the radio to turn BUT
I need to know the factory amp turn wire and where to ground the radio because I was testing it on the E-brake plate and its not long to reach....
Old Jul 29, 2006 | 08:57 PM
  #139
JEXTEL's Avatar
any help would do.......
Old Jul 30, 2006 | 06:53 AM
  #140
nismos14's Avatar
§è~® f®ÈÄk
Why the hell didn't you buy a wiring harness?!
Old Jul 30, 2006 | 07:39 AM
  #141
JEXTEL's Avatar
Im broke and wont have any money until the 18th.....
Old Jul 30, 2006 | 11:38 AM
  #142
JEXTEL's Avatar
now i just need to know the factory amp turn on, im going to extend the ground to the E-Brake plate.....
Old Jul 30, 2006 | 08:25 PM
  #143
djfrestyl's Avatar
Suspension Yoda
You're kidding, right? You can't afford $8 at Walmart? Yet you spend hundreds of dollars on a system?
Old Jul 30, 2006 | 08:26 PM
  #144
djfrestyl's Avatar
Suspension Yoda
Tell me more about why you're grounding something to E-brake? I think you need to have a professional install your system, because the questions you have been asking around here do not make it seem like you can safely install a system.
Shoot me a PM, I will help you out.
Old Aug 28, 2006 | 01:40 PM
  #145
dosmoney's Avatar
i cant make a new thread so i will ask my question here. i just got a 95 max with bose. ive got a sony headunit (i know, its sony blah) and i was told @ best buy that metra kit 7550 (the generic nissan kit) will work. will it? ill probably buy scosche's version at walmart for 5 bucks instead of spending 20 at bb. but i need to know if itll work. (i realize i am compromising the sound system doing it this way, but its just a temporary fix)
Old Aug 28, 2006 | 03:22 PM
  #146
djfrestyl's Avatar
Suspension Yoda
Metra 70-7551. Get it and save yourself the trouble.
Old Aug 28, 2006 | 03:23 PM
  #147
nismos14's Avatar
§è~® f®ÈÄk
Metra 70-7551, not 70-7550
Old Aug 28, 2006 | 03:33 PM
  #148
djfrestyl's Avatar
Suspension Yoda
You slow
Old Aug 28, 2006 | 03:50 PM
  #149
nismos14's Avatar
§è~® f®ÈÄk
Tru dat.
Old Aug 28, 2006 | 03:54 PM
  #150
dosmoney's Avatar
i got the nissan kit 7551 and i also got the kit that lets you turn down the signal (the schosche # is like oe4 or something). i got it all connected, and i have no signal and no illumination from my h/u which worked fine in my old car. any ideas? i checked all of the wiring, it all seems correct
Old Aug 28, 2006 | 04:01 PM
  #151
djfrestyl's Avatar
Suspension Yoda
How exactly did you hook it up? Pictures would help. If there's no illumination, you missed a wire somewhere. If there's no signal, then you missed a bunch of wires somewhere.
Old Aug 28, 2006 | 06:29 PM
  #152
dosmoney's Avatar
i meant i got the 7550 not the 7551. or at least cc's equivilent. i missed no wires. everything is hooked up the way it should be. im not a total car audio n00b, just when it comes to this bose ****. i think it may be my HU as it used to intermittently shut off but a couple of taps and it would turn back on. damn, and im broke. no tunes in the car
Old Aug 28, 2006 | 06:45 PM
  #153
djfrestyl's Avatar
Suspension Yoda
So then what exactly is your question?
Old Aug 28, 2006 | 07:39 PM
  #154
dosmoney's Avatar
i dunno actually. damn, im gonna try to get a new faceplate cheap on ebay see if it has anything to do with that
Old Jan 8, 2007 | 08:14 PM
  #155
drees's Avatar
I would like to replace the BOSE HU on my maxima 2000 with a Pioneer 3900MP. Both the pioneer HU and wiring harness (metra 70-7550 with OEA-4 adapter) have a black ground wire. Should I connect them together or they should be attached to some metal place directly?
Thank you in advance. BTW, does anyone know why I am not allowed to post a new thread?
Old Jan 9, 2007 | 04:38 AM
  #156
clear-mind@180's Avatar
RE Antennas - on aftermarket units, and most commonly Pioneer units, the power antenna lead gets juice *ANY* time the unit is on - on any input. I know some aftermarket HU's don't do that, though - I have a Kenwood, for example, that only puts the antenna up when on AM or FM (not AUX, CD, CD CHG, etc).
Old Mar 22, 2007 | 07:26 AM
  #157
iamatis's Avatar
After reading all of this I'm just going to tear out all the bose stuff. Once you have good quailty sound in your car there is no going back.
Old Apr 21, 2007 | 04:15 PM
  #158
surrealfiend's Avatar
i'm trying to hook up the metra 7551 now and am having problems. we have everything figured out except for that blue/white stripe "amp turn-on" wire that this guy mentions. what does this hook to??? i cannot find this anywhere.
Old Apr 21, 2007 | 04:16 PM
  #159
djfrestyl's Avatar
Suspension Yoda
It connects to the turn on lead for your Bose amp.
Old Apr 21, 2007 | 04:27 PM
  #160
no, the wire i'm talking about is the one on the metra harness. it connects to the car harness, but then where does the free wire on the metra end go. i just read somewhere else that it connects to the thing called "remote" or something similar on the HU. that wire on the HU is in fact blue/white stripe, which is just noticed.
