Got 554t installed for $500
Since I'm in Houston and can't get in on the GB deal for the Hornet 554t, I got it installed locally by Executive Motoring Boutique for $500. Here's what I got for $500.
- 554t with two remotes
- Remote trunk release with the hornet remote.
- Battery backup
- Interior horn ('pain generator').
So far I'm happy with it except for couple of things.
- First, the trunk lid is not tied to the alarm so it won't go off if I poped the trunk while the alarm is ON.
- The installer didn't program the door lock to be progressive (one for driver side, second one for the rest of the door). So one push unlocked all doors. I am debating whether I should bring the car back for that. What do you guys think?
- The installer didn't put in a seperated remote start disable switch. May be some of the installers here can comment whether it is necessary (Don?)
- Using the remote is rather complicated if you do anything more than lock, unlock, and start the car. It involves a series and combinations of key which I can't remember most of the time.
Don't get me wrong. I love the alarm though.
- Battery backup
Re: Got 554t installed for $500
- Battery backup
- Battery backup
progressive unlocking can be usefull, i have it on my maxima and im quite happy with it. It can be programmed if you have the install manual. Its very easy...open a door..turn the key on..off...press valet button a couple of times in series n' stuff..and its programmed. The shop can do it in 5 minits. As for the switch..it can be benificial if you have others work on your car or if you loan it out to others, i dont have a switch, i dont see a need to disable the remote start.
The reason for the manual over ride switch (remote start cutoff) is so that it is not accidentally started. It is mandatory for ALL DEI dealers to install when doing the remote starts. Example: you go to Jiffy Lube to get an oil change...oil is out,filter off,etc and some kid that is on early release from high school thinks your alarm remote is cool...plays with it...presses buttons...well you get the point.
--Don
MaxLife17
Jun 27, 2019 01:37 PM
hntwhttail
Sep 12, 2015 03:43 PM
