hey guys...suggestions please
Old Jan 13, 2001 | 08:06 PM
HoboPro's Avatar
i have 6.5 infinity kappas all aroun and a stealthbox in the trunk. i plan on getting the kenwood excelon z919. as many of you know, i had 2 rockford fosgate amps and a kenwood eq that was stolen. what would i need to power everything again? should i get 2 amps again or one larger (5 channel amp)? how much power is needed? should i get an eq? any suggestions? thanks in advance
Old Jan 14, 2001 | 06:52 AM
Micah95GLE's Avatar
Do you want the rear fill to have equal power to the front stage or do you want a more SQ setup?
Old Jan 14, 2001 | 02:40 PM
HoboPro's Avatar
hey micah...thanks for the reply....
what do you mean by "sq"? on my last setup, i believe that the rears were powered as well. i'd like to have everything powered. hope that helps
Old Jan 14, 2001 | 05:58 PM
jsmiam
In the old days, people used to recommend separate amplifiers for subwoofers and main speakers, but nowadays, it's not that big a deal. A good 5 channel amp should do you just fine.
The Stealthbox will really sound at it's best with as much power as you have money for, but roughly speaking, 150 minimum, more is always better. The Kappas are pretty efficient speakers, but again, more power always is better.. Shoot for 50 watts per speaker at least.
I like Dynamat or other soundproofing in the doors a lot, I think it makes a big difference. The Equalizer won't hurt either. You may not absolutely need one, but what the heck, go for it.
And many people once they have a subwoofer and good speakers, fade the rear speakers down so you barely can hear them, if at all, so the main soundstage is in front, not behind you. That part though, is totally up to you.
Old Jan 19, 2001 | 04:11 PM
Micah95GLE's Avatar
"SQ" means "sound quality". If you want the same amount of power all the way around, then get a 5-channel amp. That will work well and be simple.
Old Jan 19, 2001 | 06:12 PM
HoboPro's Avatar
what do you suggest to acheive great sq given what components i have? thanks
Old Jan 20, 2001 | 10:57 AM
Micah95GLE's Avatar
Well, you don't really need much power going to the rear fill, so you could save money by not buying amp channels for the rear fill. That would mean one of two setups: A two-channel amp for the front stage and a monoblock amp for the sub -or- a four-channel amp that is 1-ohm stable. Then, power the rear fill with the HU. Or you could get a five-channel amp (like I did) and keep the rear fill faded down low, but it's kind of a waste of power.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
jds22
Sep 29, 2015 02:03 PM
Marc2theMax
Sep 28, 2015 08:13 AM
zmcneely13
Sep 26, 2015 02:26 PM
