Ahhhhhh
Old Apr 5, 2003 | 09:04 PM
waveridr85's Avatar
Ahhhhhh
I finally finished hooking up my stereo and when i go to hook up the power wrire to the battery, it sparks upon contact and the fuse in my amp blows! any ideas on how i could fix this tommorow?
oh yea, if i have a 60 w fuse on the power line and the amp has a 40 w is that a problem?
the amp is a hifonics zeus 200 x 2 amp, please help
Old Apr 6, 2003 | 07:13 AM
waveridr85's Avatar
bump? please someone
Old Apr 6, 2003 | 10:01 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
ya...... leave the fuses out.....
connect the power..Buy new fuses and put them in. voila.
Now, why was it sparking?
Are your connections correct?
DId you double check?
Explain how you did your wiring thoughrouly
Old Apr 6, 2003 | 12:57 PM
erty67's Avatar
Decal Specialist
make sure your +12V and your ground are not reversed at the amp. I did that before. The fuse blew instantly.
Old Apr 6, 2003 | 08:39 PM
jmax
Disconnect battery ground cable. Connect amps with fuses. Reconnect battery ground cable when you have checked all wires and connections 3 times. Everytime you complete the circuit you will get a spark.
Cdoc
32
Jul 2, 2014 07:12 AM
Max Mutes
Sep 4, 2006 08:10 AM
Bl_asd
Aug 19, 2004 04:49 PM
ChrisA
Feb 17, 2004 05:46 PM
OWhatAThrill
Jan 30, 2001 09:42 PM
