headlights dimming, to cap or not to cap?
Old Apr 9, 2003 | 12:01 AM
max1ma97se's Avatar
ok i got a amp that says it pushing 400watt rms to one sub, i ran the amp on 4 gauge wire and have a good ground. i upgraded my battery which put out about the same numbers as a opitma battery, new alternator about a year ago 120amp i believe (whichever is on a se). NEWAYZ my headlight dim moderatley when bass hits at peak also everything else in the interior. should i get a 1 farad cap, 60 bux easy install dont have to remove anything, will this fix my problem tho i heard from some that it helps and other say caps are nothing but paper weight and eye candy, frankly 60 bux is a lot for candy... btw im not in the mood to upgrade my 4gu cable because 4gu barely fit through firewall i mean barley.
Old Apr 9, 2003 | 04:35 AM
crazyravr's Avatar
We have jsut been thru this !!!! Dont ppl read this board anymore ?
Old Apr 9, 2003 | 12:44 PM
max1ma97se's Avatar
i read them they situations seems different they have much more powerful amps than i do
Old Apr 9, 2003 | 05:17 PM
friendhasmax's Avatar
get the cap, upgrade to battery wont stop lights from dimming. if u only have a 400 watt rms amp, then 1 farad will do the job nicely. just remember to charge it correctly before installation. get a good cap though, a cheap cap will suck and not work properly (****ty dielectrics, and horrible ESR rating). the cap will regulate voltage also, so its always a good thing. drops in voltage can cause amps to clip and destroy speakers FYI
Old Apr 9, 2003 | 05:36 PM
max1ma97se's Avatar
Lightning Audio any good?
Old Apr 9, 2003 | 05:38 PM
its ok, get a STINGER HPM 1 farad or a stinger pro 1 farad
Old Apr 9, 2003 | 06:09 PM
thebigsadler's Avatar
if you don't car about looks or whatever any 1 farad cap will do what you need.. there is no need to buy one with a digital display or what have you, just get one off ebay for cheap.
if you put a 2nd battery in the car, the nit will help
jason
Old Apr 9, 2003 | 06:36 PM
jason
tell me exactly what a second battery will do for the system...it certainly wont stop the lights from dimming...try it for urself and come back to me
Old Apr 9, 2003 | 07:45 PM
Magikone69's Avatar
i personally dont understand why anyone one put a second battery in. Not only would the altenator have to charge the main battery but wouldnt it have to charge the 2nd one also. That seems like alot of strain on our altenator. my friend installed a cap after noticing his lights were dimming, he had an amp doing 800 watts and he put in a cheap DHD 1 farad cap and it did the job.
Old Apr 9, 2003 | 08:05 PM
thank u Magikone69, ur a smart man
Old Apr 9, 2003 | 09:47 PM
works pretty well for me.. battery isolator between the two, no caps.. my lights always stay nice and bright and i am pushing 1000watts along with a crapload of other electrical stuff.
one redtop up front and a yellow top in back.
Old Apr 9, 2003 | 10:31 PM
DanIAm's Avatar
i havent tryed out a cap yet, im runnin a ampman revo with 2 volfenhag 12's temp. till my brahma gets fixed and i can deal with lights diming but somthin to look at b4 buying a cap...just good info to check out i guess, i posted it a while back
http://pub51.ezboard.com/fcaraudiokn...picID=33.topic
Old Apr 9, 2003 | 11:19 PM
max1ma97se's Avatar
flucking hell, this response is what i get everywhere, one says yes it will work other say it is useless. WILL THIS HELP ME!! (not people pushing 10000 watts rms) dont want tech jargon, from personal fricken experience did this solve your problem or at least helped???
Old Apr 10, 2003 | 01:23 AM
tafan321's Avatar
like 3/4 of them said to get one...so get one...done and done
Old Apr 10, 2003 | 08:15 PM
get one cause it works. i can explain how if u like, but just get one. a battery will not be a better choice for numerous reasons
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
Noela
Sep 26, 2015 08:22 AM
