Tweeters
Old Apr 20, 2003 | 08:54 AM
GrkMchn's Avatar
Tweeters
I blew my right front speaker, the tweeters are fine, but I have to upgrade. What are the advantages of upgrading the tweeters as well as the speakers. I am tight on cash and can get a decent component system or just a really nice set of speakers, what do you think??
Old Apr 22, 2003 | 08:28 PM
maximalnemisis's Avatar
Re: Tweeters
yo man you have to change the whole speaker system because the bose system is really wacked out it .....it runs offa a 4ohm instead of 2 ohm, like regular aftermarket stereos
Old Apr 22, 2003 | 09:18 PM
Supa Lao's Avatar
Is it bose? If so, you have to change out all 4 speakers and radio. Bose spkrs have there own seperate amplifiers in them and run at 1 ohm.
If it isn't bose, you are in better luck. Do you plan on doing a full out system? If so, I would go w/ components. If not, I'd just throw in some nice coax spkrs in there
Old Apr 23, 2003 | 06:38 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Re: Tweeters
Actually Bose runs at about 1Ohm, and most common aftermarket speakers run at 4Ohm.
--Don
Old Apr 23, 2003 | 06:41 AM
GrkMchn's Avatar
I purchased a full component system, but now the tough part will be installing it, any advice
Old Apr 23, 2003 | 09:16 AM
Neal728's Avatar
Whoa Whoa Whoa! If you have a 5th gen you can just switch out a tweeter, they run at the same impedance as aftermarket. I have pioneer tweeters in my 2K2 with Bose, just wire em up, put a capacitor on them and you're good to go.
Old Apr 23, 2003 | 09:19 AM
GrkMchn's Avatar
4th gen nonbose
Old Apr 23, 2003 | 12:31 PM
Dohcser's Avatar
4th gen nonbose
Just replace them and you will be fine, it does not sound like you have any external amps....etc.
Old Apr 23, 2003 | 12:56 PM
GrkMchn's Avatar
No, I don't but what if I want to hook one up later?
Old Apr 23, 2003 | 01:20 PM
Dohcser's Avatar
If you did hook up one later, you would want to run seperate wires to them, rather than using the stock ones!
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
1MAX2NV
Jun 19, 2001 12:27 PM
hlh0501
Jan 29, 2001 04:17 AM
ericdwong
Jan 26, 2001 05:51 AM
