2002 SE Stereo Install Help Please
Old Apr 22, 2003 | 04:23 PM
Tone8969's Avatar
Just picked up my Max this past friday, I like the idea of the steering wheel controls for the radio n all, just looking to add a SUB to my NON-Bose stereo.
I got one of those LineOut Converters that splice into the rear speaker wires for the RCA jacks, but is the only way to access those wires to go behind the radio? If so, how do you get to it, doesnt look very self explanatory on how to remove panels.
Also, those of you who have wired up power and ground cables for amps, did you guys go straight off the battery, or off of another 12v source?
Where did you put the ground?
ANY help is much appreciated, im not too familiar with maximas, imports more less, this is my first foreign car.
responses or emails are much appreciated
Tone8969@aol.com
Old Apr 23, 2003 | 11:38 AM
Dohcser's Avatar
Re: 2002 SE Stereo Install Help Please
Tone8969@aol.com
I would not use just any LineOut Converter, PAC sells one specifically for our cars and it is a cleaner install for adding an amp to your factory system.
Part #
AOEM-NIS2 MAX 95-02
AOEM-NIS1 MAX pre 95
If you are adding a seperate amp, definately run seperate ground and power wires. The power wires should be ran directly from the battery with an inline fuse, and the ground should be tapped into the cars chassis close to where the amp will be mounted!
MaxLife17
Jun 27, 2019 01:37 PM
Smackasmith
Feb 1, 2016 12:40 AM
GregL65
Sep 7, 2015 10:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
