4 channel amp
Old May 4, 2003 | 03:32 PM
GrkMchn's Avatar
4 channel amp
would I be able to use a 4 channel 800W amp to power both my front components and my rear speakers?
Old May 5, 2003 | 12:04 PM
hrygeek's Avatar
by rear speakers do you mean subs?
Old May 5, 2003 | 01:53 PM
GrkMchn's Avatar
no, I mean the speakers in the rear deck
Old May 5, 2003 | 02:29 PM
hrygeek's Avatar
then the amp should be fine. what's the amp rated at? what kind? what kind of speakers? seems overkill for some components unless they're pretty stout rms numbers.
Old May 5, 2003 | 05:28 PM
GrkMchn's Avatar
I don't have an amp, but was looking to get one for them. The rear speakers are Boston Acoustics and the components are Infinity, any suggestions on an amp that would be good but for not a lot, I'm pretty sure the max W on the speakers is around 200W per speaker
Old May 5, 2003 | 09:33 PM
hrygeek's Avatar
infinity kappa 605cs' run about 90w rms. boston coax's can't be more than that. you could get away with a 100X4 amp. as far as brands, that's like asking which beer is better. everyone has a different opinion and if you've had good luck with a certain brand, stay with it. i personally like autotek amps for mids and highs and orion amps for subs. kicker, jl audio, audiobahn, etc will work for mids and highs. it's your choice. i wouldn't try to kill those speakers with a monster 4 ch amp.
Old May 6, 2003 | 04:29 AM
GrkMchn's Avatar
so it will be relatively cheap? do you have any idea how to hook the speakers up to the amp?
Old May 6, 2003 | 08:35 AM
hrygeek's Avatar
do you have the car prewired for an amp? if not, you will need an amp kit. stock deck or aftermarket h/u? if stock deck, you will need line converters to convert high level inputs to low level. this step isn't necessary but saves time and wire running. i need more info as to your question.
Old May 6, 2003 | 01:14 PM
GrkMchn's Avatar
I have the stock HU, but used to have subs, so I have an amp kit, and the lines are still in the trunk
Old May 6, 2003 | 01:34 PM
hrygeek's Avatar
i don't understand by what you mean wiring the speakers
Old May 6, 2003 | 02:28 PM
GrkMchn's Avatar
Basically what I want to do is power my speakers with an amp, I already have an amp kit, I was just wondering how I would go about connecting the speakers to the amp and where would I run the wires to power the front components
Old May 6, 2003 | 03:40 PM
hrygeek's Avatar
I always run new wires to each speaker. that way I leave the stock stuff alone. run new wires down the door channels and you should be fine. run all the wires to the trunk and set it up
Old May 6, 2003 | 04:08 PM
GrkMchn's Avatar
do you know of any write-ups?
Old May 6, 2003 | 04:28 PM
hrygeek's Avatar
http://maxima.cardomain.com/id/2k2kevpearlse
Old May 6, 2003 | 05:22 PM
GrkMchn's Avatar
thanks
Old May 6, 2003 | 08:21 PM
GrkMchn's Avatar
do you think this would be plenty?
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39741
in case you couldn't see the paper, it says 75W x 4
Old May 6, 2003 | 11:34 PM
hrygeek's Avatar
what price range are you looking for? the one above is only 25w per channel at 4 ohm. better than stock but not the greatest. try a kicker 300.4 or 600.4 or try something from another maker. If you have a favorite, stick with them. stay away from the legacy and such but most 75wX4ch will work. unless your running seperate x-overs, try to get an amp with built in x-overs. if you need anymore help, email me @ hrygeek@***.net
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
minsbang
Sep 5, 2015 05:36 AM
