Headunit powered off amp/sub hmmm?
Old May 27, 2003 | 01:35 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
RF 8-gauge amp kit was used and is run down the drivers' side to an Infinity BassLink(200W RMS internal amp). I believe this is something new, but maybe I just never noticed.
I'm going to investigate this weekend and try a different grounding point. Any other tips/tricks BESIDES moving the power wire to the passenger side?
Old May 31, 2003 | 12:48 PM
IceY2K1's Avatar
*bump*
Old May 31, 2003 | 01:18 PM
chinaonnitrous1's Avatar
Re: Headunit powered off amp/sub hmmm?
Your basslink shut off? If it did i would just grab a volt meter to check the Remote turn on/power wire for 12V. The ground shouldn't matter. If the ground worked before, it should be okay.
Old May 31, 2003 | 11:02 PM
IceY2K1's Avatar
Re: Re: Headunit powered off amp/sub hmmm?
No, the BassLink is still on, but the headunit is off. I get a hmmmmmmm sound even when the engine is off.
Old Jun 1, 2003 | 07:37 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Re: Re: Headunit powered off amp/sub hmmm?
What headunit are you using? Is it the stock one? If so, then the problem is..when the radio is off the Basslink is still powered, but no signal is going to it. Therefore giving you the humming noise.
--Don
Old Jun 2, 2003 | 09:41 AM
IceY2K1's Avatar
Re: Re: Re: Re: Headunit powered off amp/sub hmmm?
--Don
Yes, stock.
So that's normal then. I guess I never noticed it before.
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
