ROEM install
Old Jun 6, 2003 | 06:15 AM
slop00's Avatar
ROEM install
I'm trying to install an Alpine CDA-7873 in my 99 maxima with bose. I got the ROEM NIS-2 kit from pac but tried to install it last night and headunit didn't power on of anything. I have installed numerous systems in non-bose cars and I've never had any trouble.
I see on the harness I got with the pac it has 18 wires and my headunit doesn't have that many wires to splice together. I think it has to do with the low level and high level wires for each speaker. Any help would be greatly apprieciated.
Slop
Old Jun 6, 2003 | 12:17 PM
slop00's Avatar
bump
Old Jun 7, 2003 | 02:36 PM
studman's Avatar
Make sure the +12v ignition and +12v battery wires coming from the ROEM are connected properly to the HU.
Also, check the fuse on the back of the HU (and in the fuse box of the car) to make sure you didn't accidentally blow a fuse too.
Then check the ground wires.
The ROEM kits allow you to wire up the aftermarket HU to the adapter using either line-level or speaker-level inputs. That's why there are an extra set of wires coming from the ROEM kit. Only use one or the other.
Oh, and make sure you turn the car on so the radio will have power, but I assumed that you already knew this one.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
