best sound?
Old Jun 7, 2003 | 02:58 PM
raymond3414's Avatar
best sound?
I just got my Diamond Audio speakers in, and I wanted to know what is the best way to go for the best sound? Should I go with a spray for the doors or some sort of dynamat?
Old Jun 7, 2003 | 08:46 PM
mingo's Avatar
if you plan to spray, u're going to have to use multiple cans per doors because the film it sprays out is very thin, i would recomend using some heavy duty soundn deadening material thicker than dynamat extreme. do not use any sponge type material inside the door panel because it'll get soggy when it rains and peel off then it'll get jammed inside your window tracks
Old Jun 8, 2003 | 10:19 PM
So what would you suggest the product that I should use. I don't know of any products other than dynamat and cascade. So hit me back.
Old Jun 9, 2003 | 04:30 AM
crazyravr's Avatar
Brown bread. Best stuff I ever used. Cheaper then dynamat and works wonders.
Old Jun 9, 2003 | 04:53 AM
mingo's Avatar
hehehe that's what i tried replying with, but for some odd reason i couldn't reply.. yeah brown bread has been mentioned alot in the audio forum i used to participate in. and i've had bad prior experiences with raammat. however i heard they reformulated.
Old Jun 9, 2003 | 06:09 PM
So brown break is the way too go is what your all saying? Would that be a spray or a sheet?
Old Jun 9, 2003 | 06:54 PM
mingo's Avatar
it's sheets.
Old Jun 10, 2003 | 01:20 AM
Nismo's Avatar
is brown bread an actual audio dampening material or is this a "home depot" method like that peel and seal?
Old Jun 10, 2003 | 06:24 AM
jmax
There are two answers to that question. "Yes" and "No". Both are correct. It's the same as dynamat extreme, edead, ramm mat, etc. All are based on an aluminum roof flashing material such as peel & seal. Every once in a while you get an old roll or a roll that didn't have the adhesive mixed as well. Brown Bread is marketed as dampening material.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
