Anyone run aftermarket deck wioth bose speakers...possible ?
Old Jun 29, 2003 | 06:15 PM
madmax97's Avatar
Anyone doin it, is t do able want tvs but no do for new interior speaks...
Old Jun 29, 2003 | 06:35 PM
SuperChris's Avatar
Infiniti 35 Double G's
Re: Anyone run aftermarket deck wioth bose speakers...possible ?
I'm doin' it now, even though you're not supposed to...
Old Jun 29, 2003 | 09:03 PM
madmax97's Avatar
can you inlighten me on what your set up is...how you running it ext. Also you need any diff parts adapters, you think it be easy to hook up tv aftermarket deck dvd player to it ?
Old Jun 29, 2003 | 11:21 PM
98 DBL Black's Avatar
You can do it, you will need to go here http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
and look for the wiring scrmatic (sorry for the spelling) for your year. You will need to connect the "factory amp turn on wire" to your wire that tells your amps to turn on (usually labled "swiched") and the factory ground wire.
Old Jun 30, 2003 | 01:47 PM
silver99
ok i guess i know what you mean. i can understand the subject but you totaly lost me on that babble "Anyone doin it, is t do able want tvs but no do for new interior speaks..."
you can buy urself a nifty little adapter to use the oem bose system with a new head unit. they run about 65 dollars. forget wiring it yourself you will only cause yourself headaches. If you purchase the better version of the adapter you can adjust the gain on output.
Old Jun 30, 2003 | 09:14 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have it done on my car right now. I am runing a clarion head unit with the bose speackers that came on my 97. It is a very easy thing to do. I went and got a part called a interface converter. It makes it wheer bose speakers work with other head unit. very easy. it cost like $50. I am chaging the crap bose out anyways.
Old Jul 3, 2003 | 12:37 AM
Jared611's Avatar
http://www.affsave.com/pac4.htm
Old Jul 3, 2003 | 08:12 AM
Drew96I30's Avatar
I think I have one of those adapters lying around somewhere. I'll sell it to you cheap if you want it. I had it in my car when I had my screen and dvd and stuff, before I replaced the bose speakers. It worked like a charm. Let me know if you're interested in it, and I'll try to dig it out.
regards,
Drew
Old Jul 3, 2003 | 03:20 PM
PE1976's Avatar
bose adaptor
If you dont sell it to him, Im interested, Im about to buy a new headunit and need that adaptor, let me know......
Old Jul 3, 2003 | 03:55 PM
Drew96I30's Avatar
Re: bose adaptor
alright, i'll take a look around for it and get back to you by tomorrow.
-Drew
Old Jul 4, 2003 | 11:59 PM
maximaseefu's Avatar
you don't really need the adapter, i installed my excelon with just wiring harness from best buy, it's all color coded and cost about 15 bucks. i ran it for about a year before i took out my bose and replaced with type r components. as a matter of fact those pillar speakers are still going strong since i never replaced them.
Old Jul 5, 2003 | 12:06 AM
Drew96I30's Avatar
correct you dont need the adapter, it helps though...I put my Head Unit in without the adapter first and the volume control wasnt as accurate. When I put the adapter in it sounded a bit better too IMHO.
Old Jul 5, 2003 | 06:32 AM
I30Jay's Avatar
Hey,if I rip out my bose 61/2's in the front and replace with two ways and no adapter on my aftermarket headunit, will the tweeters still play????
Old Jul 5, 2003 | 08:40 AM
Drew96I30's Avatar
nope, you'll see why after u take your door panel off and see the bose amp.
Old Jul 5, 2003 | 06:30 PM
bump
captchaos
Mar 15, 2016 12:18 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
A32goldylocks
Sep 2, 2015 06:39 AM
