adding amp to bose
Old Jul 25, 2003 | 12:25 PM
maxdrvr847's Avatar
adding amp to bose
i have a 99 max with bose, I know they make an adaptor so you can hook up rca cables, but they also make those hi-low conv. that you could install on rear speakers. those work similar or better to get the actual adaptor?
also where would be the best place to hook up the remote wire?
Old Jul 25, 2003 | 01:12 PM
maximamaybe's Avatar
The AOEM-NIS2 will work better than the high-low converter because it plugs in prior to the amplifier. Therefore, you are not converting distorted signal.
Old Jul 25, 2003 | 01:32 PM
maxdrvr847's Avatar
where is the best place to get this part?
Old Jul 25, 2003 | 02:56 PM
erty67's Avatar
Decal Specialist
http://www.affsave.com/pac5.htm
Old Jul 25, 2003 | 04:31 PM
Old Jul 25, 2003 | 08:22 PM
omsmax's Avatar
what about the PAC SNI-35, will that work too, or the AOEM-NIS2 work better. I am in the same boat try to add a amp/sub to 98 max with bose.
thanx
Old Jul 26, 2003 | 05:14 AM
erty67's Avatar
Decal Specialist
I just used a line-level converter and it sounded fine
Old Jul 26, 2003 | 06:10 AM
omsmax's Avatar
erty67,
when u add your line-level converter, where did u tap into the bose hu or the rear speakers. i noticed there are 2 wires (red,black) and then 4 or 5 more wires onto the rear sp. can u help me out with the connection wires.
thanx
omsmax
Old Jul 26, 2003 | 09:39 AM
erty67's Avatar
Decal Specialist
Originally posted by omsmax
erty67,
thanx
omsmax
When I used the line-level converter, I just tapped into the speaker wires that go from the amp to the cone. I just had to drop the amp down form the bottom of the speaker. There is three screw that hold it up. I used the remote wire for that amp to power the converter.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
