Sub And Amp Ohm Load Question
Old Jul 27, 2003 | 06:02 PM
ILOVEMYSE's Avatar
I just bought a Rockford 500S amp and I wanted to know if I could run 2 of these subs at 2Ohms?
http://www.pioneerelectronics.com/Pi...9,1987,00.html
Old Jul 27, 2003 | 06:24 PM
filtor1's Avatar
Re: Sub And Amp Ohm Load Question
Here is a good site. http://elliottelectronics.com/Spkwiringset.htm
Old Jul 27, 2003 | 06:51 PM
ILOVEMYSE's Avatar
Re: Re: Sub And Amp Ohm Load Question
Thanks man I apprciate that. So that means I can wire them in parallel and run the amp at 2 ohms to one channel am I reading that correct?
Old Jul 28, 2003 | 04:40 AM
Big_Ham's Avatar
MaximaFreak
Re: Re: Re: Sub And Amp Ohm Load Question
All I can tell you is that filtor1 is right, this will introduce a 2 ohm load to your amplifier. Now, whether or not that amplifier can handle a 2 ohm MONO load, I'm not sure. You should check the specs and see what it's stable to.
Old Jul 29, 2003 | 10:03 PM
erty67's Avatar
Decal Specialist
unless your amp is rated for 2ohm stable in mono(which it's not), don't do it. You can hook them up two channel. You would just be running at 4ohm per channel.
Specifications
stereo or bridged mono output
Tri-Way capable
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms in bridged mode
how about these? dual 4ohm coils = 2ohms
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3291
...just a suggestion
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
popdedop
Sep 11, 2015 11:17 AM
