amp crossover settings
Old Aug 10, 2003 | 04:19 PM
AscendantMax's Avatar
what do you guys set your low pass crossover on your amp at? I have mine at 100 Hz but my so friend thinks that a bit high and should be at 80 Hz instead. any input?
Old Aug 10, 2003 | 05:34 PM
erty67's Avatar
Decal Specialist
i agree 80hz seems to be a good spot, but there is nothing wrong with using 100hz.
Old Aug 10, 2003 | 08:12 PM
spirilis's Avatar
I like my front & rears at 80Hz, subwoofer at 125Hz (12dB/octave slope).
My Pioneer amps have passive crossovers builtin that are fixed at 80Hz, 12dB/octave (though I use the active crossover in my Alpine H/U instead)
Old Aug 11, 2003 | 08:38 AM
Kojiro_FtT's Avatar
Re: amp crossover settings
Try it and see how it sounds to you. I actually switch it back and forth from my HU. I change the sub LPF from 100 to 80 and back, and the HPF on the fronts vise-versa. With some of the bass heavy music, you will get tighter hits with a lower LPF setting, cuz the sub can concentrate more on those hits.
Old Aug 11, 2003 | 09:35 AM
i actually did try that this morning. with it set at 80 and some bassy songs, the subs hit a wee bit harder. at 100 it helps out with the higher bass. think i'll keep it at 80
thanks for the replies!
Old Aug 11, 2003 | 09:54 AM
HuliganRS's Avatar
80 is good.
Old Aug 11, 2003 | 10:20 AM
erty67's Avatar
Decal Specialist
80hz is pretty standard in amps with a non-adjustable low-pass crossover.
Old Aug 11, 2003 | 01:21 PM
Pearl96Max's Avatar
I tend to get a bit irritable
The important question is what size/how many subs are you using? 80 is pretty standard, 50-60 is Very safe. But all of this depends on what you have.
--Don
Old Aug 11, 2003 | 02:16 PM
two fosgate HEs 10s in a sealed box with a 400s amp pushing it.
Old Aug 11, 2003 | 03:59 PM
Pearl96Max's Avatar
I would say 80 then.
--Don
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
