how to install a cap???
Old Aug 13, 2003 | 10:31 PM
krmaxima's Avatar
i need to know the basic set up????
thanks
Old Aug 13, 2003 | 10:49 PM
MrGone's Avatar
hope that helps.
Old Aug 14, 2003 | 12:03 AM
Parsec's Avatar
so you're saying it goes between the dist. block (if applicable) and the amp, right?
Old Aug 14, 2003 | 03:36 AM
maximaseefu's Avatar
between distribution block and battery.
Old Aug 14, 2003 | 09:09 AM
TAPOUT's Avatar
You will lose
It is better to have a separate ground for the amp and the cap. Only the Positive wire should go from the cap to the amp. DO NOT put a fuse between the cap and the amp. Make sure to charge the cap before hookup so there are no sparks when the connection is made. It will leave a burn bark on the gold plating, and be careful not to overtighten the screws on the cap. They strip very easily, and are a pain in the A$$ to fix.
Old Aug 14, 2003 | 09:38 AM
krmaxima's Avatar
does the ground have to go back to the battery from the cap??? or should i just ground it anywhere????? and how do i charge the cap before i put it in?????
Old Aug 14, 2003 | 11:52 AM
you can charge it with a trickle charger. like the ones that charge your car battery overnight.
Old Aug 15, 2003 | 09:15 AM
TAPOUT's Avatar
You will lose
I usually charge my cap with an old test light, but it should come with a resistor. And the best way to ground it would be to find a good solid piece of metal, usually near some factory weld marks, sand a small spot down to bare metal, and drill a 1/4 inch hole. Then use a stainless steel nut, bolt and lockwasher to secure it through the ring connector.
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
220k+ A32
Sep 11, 2015 02:18 AM
boomerbrian
Sep 2, 2015 03:46 PM
