What dB could I hit with.....
Old Feb 8, 2001 | 10:20 PM
wesley
One 12" Power Acoustic Kevlar Farenheit Subwoofer (1000 rms/2000 peak)pushed by a Profile 1200sx Amplifier (900x1 rms). I also plan on getting a crossover for the sub so it doesn't play so high. Any recommendations. I have a sealed box, but I don't have the measurements. Any estimates on the dB would be great. Thanks in advance. Also, does anybody have a custom installation to save space in the trunk, or any recommendations.
CK-12D
Kevlar Fiber, Ceramic Coated Cone
Oversize Butyl Rubber Surround
Dual Hybrid 4 Layer 4 Ohm Voice Coil
3" High Temperature A.S.V. Voice Coil
Low Q Driver (.75~1 CUFT. Sealed Box)
224 oz. Magnet Structure
Maximum Input 2000 Watts
R.M.S. Input 1000 Watts
Imp. 2 Ohm, 4 Ohm, 8 Ohm
Freq. Resp. 18Hz-1kHz
1200sx
2-ohm stable in stereo
450 watts x 2 into 2 ohms
600 watts x 2 peak power
900 watts in bridged mode
continuously-variable high-pass and low-pass crossovers (40-130 Hz at 12 dB per octave)
105 dB signal-to-noise ratio
45 Hz bass boost (continuously variable, 0-12dB)
Old Feb 9, 2001 | 02:09 AM
SWEETSOUND2001's Avatar
dude...how much are you getting this stuff for? those are really low end manufacturers with inflated specs...email me and i will help you out...
Old Feb 11, 2001 | 10:18 AM
ray89se's Avatar
igot
i have a kenford 9000 watt amp (pmpo)and a kracko 8" triple voice coil with a 10 inches throw... i bet i can get 178DB's out of this thing.... buy the way im running telephone wires for all the amplifier connections
Old Feb 11, 2001 | 04:35 PM
wesley
yo
your system is straight ghetto
Old Feb 12, 2001 | 03:19 AM
ray89se's Avatar
my system maybe ghetto
but my car sure does look good
Old Feb 15, 2001 | 12:06 AM
Nismo's Avatar
to ray89se
hey ray89se- how did you wire the neon to the doors? did you solder longer wires? did you run the wires straight to the battery?
Old Feb 22, 2001 | 01:54 PM
CanuckAMP's Avatar
wesley:
I'd certainly look for other brands, these guys are trying to steer you away from a pretty bad brand of car audio equipment for a good reason.
D Mason
Jun 21, 2016 04:43 AM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
