Installed New Rear Speakers, Barely Hear Them, Why?
Old Sep 9, 2003 | 06:42 PM
SuperChris's Avatar
Infiniti 35 Double G's
My current set-up: Kenwood HU & stock Bose speakers (no adapter)
Saturday I put in some new speakers in the rear; tested them out, and I could barely hear anything. Had to turn the volume up past 20 to get some sound.
My questions:
- If I wired them incorrectly, would I be hearing anything at all?
- If I wired them correctly and they sound like sh*t, does that mean I have to get an amp to hear them?
- Since I still got the Bose speakers in the front, is the HU sending all the juice to those and next to nothing to the back speakers?
Help is greatly appreciated...
Old Sep 11, 2003 | 01:44 PM
DJ Kontakt's Avatar
Ok, if you wired them incorrectly , you wouldnt hear much. Most likely, one speaker is wired correctly, and the wires on the other are switched. THis means when one speaker goes in, the other goes out. (the phases are reversed). THe wave from one will cancel out the wave from the other. THe other posibility is that the Phases are reversed on BOTH of the rear speakers, and the front is cancelling out the back. This is the most logical explination, BUT I dont know anything about the bose amplifier. Try switching the wires, and see if it fixes the problem.
Old Sep 11, 2003 | 01:51 PM
AscendantMax's Avatar
that kenwood hu should be able to push those new speakers. did you check the front/rear balance on the HU? i know that sounds silly, but doesn't hurt to check
Old Sep 11, 2003 | 03:05 PM
Gjohnson's Avatar
I'm guessing that you have ran new speaker wire from your head unit to the bose speakers to bypass the bose amps, correct?? Well, like the post above definitely check your connections and make sure yours speakers are wire correctly.
Old Sep 11, 2003 | 06:32 PM
SuperChris's Avatar
thanks for the input er'ybody...i'm gonna investigate things this weekend.
Old Sep 13, 2003 | 11:08 PM
nismos14's Avatar
§è~® f®ÈÄk
that would fry the Kenwood HU because the bose speakers run at 1 ohm, and the HU is only meant to run at minimum 4 ohm speakers
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxboy23
Aug 20, 2015 09:33 AM
Dman1989
19
Aug 17, 2015 03:44 AM
Mcnabb34
Aug 11, 2015 08:45 PM
