Antennae problem
Old Sep 14, 2003 | 01:10 PM
PeTeRtheEaTeR's Avatar
Antennae problem
need help with my antennae, it's in that slot, but it doesn't go up or down, and when i listen to the radio...it's pure static..so i'm guessing that the antennae isn't active...so i was wondering if someone can tell me how i can fix this myself.
Old Sep 14, 2003 | 09:49 PM
thomasd cook's Avatar
You probably need to hook the remote line of your radio to the ant. wire.
Old Sep 15, 2003 | 01:42 AM
oh...that was a simple answer..thanx...but how do i hook that up? should i go to a mechanic?
Old Sep 15, 2003 | 06:06 AM
Dohcser's Avatar
If you replaced your head unit you probably did not hook up the antenna power wire to either your Remote Turn on wire or some Head Units have a dedicated power output for ANTENNA. But it sound like your antenna is up already which you should be getting reception anyway. You might want to check the antenna adapter hookup.
Old Sep 15, 2003 | 07:14 AM
You just swapped out your head unit correct? You need to take your remote turn on wire and hook it to the power ant. wire. If you used a wiring harness then there should be a wire in the harness for the ant.
Old Sep 16, 2003 | 12:55 AM
ok thanx...i'll probably do it sometime this weekend....thanx for all your help guys
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
