need every1 opinion, what can i do to stop my lights from dimming??
Old Sep 22, 2003 | 08:44 PM
95seMax's Avatar
i have a pioneer 700 watt amp bridged pushing two 12" fosgate hx2 (think 1000 watts )
i also have a 1 farad cap connected
with the cap still conected to the system my lights will dim out every time the bass hits,
will the lights wen they dim , will that cause my battery /alternator to to fail ?
do i need a better battery or another cap ? or anything else?
would gettin an optima battery solve this problem ?
should i get another cap? i taught a 1 farad cap is supposed to be good up to 1000 watts , i only have a 700 watt amp
if i leave my lights dimming will it cause my battery/ alternator, wire harnesses, etc to burn out
thanks for any help
Old Sep 22, 2003 | 11:10 PM
kgb006's Avatar
you should gey a Optima D34/78 Yellow Top ... that should fix that problem
Old Sep 23, 2003 | 01:56 AM
95seMax's Avatar
that should fix it?
is yellow the best one to get wen u have system in car?
i know they have blue, red , n yellow, not sure which ones best
is it a direct fit for our cars?
Old Sep 23, 2003 | 09:06 AM
TAPOUT's Avatar
You will lose
97 out of 100 times you don't have a good ground. You aren't running enough power to overload the stock system. Make sure your ground is the same size wire as the positive, and is grounded within 18 inches of the amp. Make sure there is no paint where it is grounded, and make sure your ground is tight.
Old Sep 23, 2003 | 11:27 AM
Igor911's Avatar
you might want to upgrade to a bigger cap....
Old Sep 23, 2003 | 11:42 AM
97GLES's Avatar
the maxima is known for it's lights dimming all the time.
you hit the power lock and the lights dim.
you go up with the windows and the lights dim.
i only have 2 amps.
the only way i helped my system was by adding:
new 125 amp altinator (oem)
2- optima red top batterys
2- 1 f caps.
Old Sep 23, 2003 | 12:56 PM
95seMax's Avatar
i just checked the ground everything looks fine , its about 12 inches away from the amp, there is no paint on the surface n the ground wires are the same
97gles wow all that work , does your lights dim at all?
also wat would happen if u leave ur lights dimming , would it possibly burn out the battery/alternator , wire harnesses?
Old Sep 23, 2003 | 05:22 PM
sk24iam's Avatar
Try upgrading the 3 wires from the alternator.
Old Sep 23, 2003 | 06:49 PM
97GLES's Avatar
95seMax
it's very easy to kill a battery but you don't want to kill the alternator. it will cost alot of $$$ and down time to fix.
i rather change the battery 10 times before i have to change the alternator.
Old Sep 23, 2003 | 07:45 PM
spencediggy's Avatar
listen to me man.....this is my 2nd max....this is a common problem. on the 1st max...i rebuilt my alternator from 12 to 14volt, without a 1 farad cap, new gold series sears battery pushin 500watt 2ch FOSGATE amp n 600watt 4 ch AMPLE amp, but now i have (2) 1 farad caps, red top OPTIMA battery pushin 750watt mono MTX amp n 600watt 4 ch AMPLE amp. no probs now...but im gonna install crazy TV's, so im adding a 2nd OPTIMA battery in the back.
Old Sep 23, 2003 | 08:21 PM
97GLES's Avatar
most all maxima's alternators run between 12.5 & 14.2 volts.
if you are running more than 14.5 volts that means your regulator is shot & your amp will break down soon.
i went from a 110 amp to a 125 amp (oem)
you can get a 180 amp alternator from ohio generators but you will need to install new brackets so it can fit.
Old Sep 25, 2003 | 06:47 PM
Bumpin_Grey_Max's Avatar
Man I don't know what ya'll are talkin about as far as the max having chronic problems with the lights dimming.... I have 3 power HX2 12's, with 3 fosgate bd.1000 amps, I hit 152 db all day long, and I still have my stock battery with no caps.
My Lights are bright and pretty, with no dimming....just a thought
Old Sep 25, 2003 | 07:28 PM
WOODYMAX98's Avatar
Where can you buy a higher amp alternator? Thanks
Old Sep 26, 2003 | 07:55 AM
97GLES's Avatar
nissan (oem) 125 amps
ohio generators has one thats 180 amps
Old Sep 26, 2003 | 12:28 PM
TAPOUT's Avatar
You will lose
You may want to start rewiring the stock wires under the hood.I have 0 guage run over to the engine block, and that took care of a few problems. I have better throttle response (better spark) and my big Xtant amp doesn't dim my lights at all. I also have 0 guage run to the trunk, and a stainless nut, and bolt with lock washer to ground it in the trunk. I haven't had any light dimming problems with Maximas. I just installed a 1600 Watt RMS PPI amp in my friend's car with no problems.
Old Sep 26, 2003 | 02:10 PM
maximafever's Avatar
the only power upgrades I have in my car is an Everlast Deep Cycle Marine battery, no caps at all. Running 600watt Bazooka Mono Amp, 200watt MTX 2channel amp, playstation 2, 1 screen and my lights barely dim
Old Sep 26, 2003 | 06:41 PM
WOODYMAX98's Avatar
what else did you do under the hood beside ground the battery with 0 gauge.
tsi6001
Oct 3, 2022 10:23 PM
mvm062
Nov 30, 2020 09:00 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
