OEM remanufactured Bose speaker and amplifier replacement info (only $85)
Old Feb 16, 2001 | 10:04 AM
Maxima95GLE's Avatar
I accidentally put this in the general discussion area and finally put it here in the right forum. Anyways, If you're having problems w/ your Bose speakers and/or amplifer, think again before you decide to junk the whole system (unless, of course you want to) or purchase a new speaker assembly. At the bottom is a TSB from Nissan and it details how you can just contact Clarion directly to exchange your Bose speaker/amplifier unit (yes, that's right, the whole assembly, not separates), and for $85, you can exchange it to have a remanufactured unit (made back to OEM specs) sent back to you.
I hope this helps some of you. Also, Clarion (1-800-347-8667, customer service) will fix your Bose decks as well, if you are having problems, however, you will have to call them to get an estimate on cost.
Remanufactured Bose Speakers
Classification: PI95-013
Date: July 5, 1995
REMANUFACTURED BOSE SPEAKERS
APPLIED VEHICLES:
All equipped with Bose system
SERVICE INFORMATION
Nissan and Clarion are working together to help keep down the cost of repairing Bose speakers after the customer's vehicle warranty has expired. Remanufactured Bose speakers are available as exchange units to replace incident speakers instead of installing new ones. This cost effective alternative should be explained to all customers requesting out-of-warranty speaker replacement.
SERVICE PROCEDURE
If a Bose speaker requires replacement in an out-of-warranty vehicle, please offer the customer the following option:
1. Remove the incident speaker as an assembly. The entire speaker enclosure must be intact for a valid exchange.
2. Send the complete speaker assembly and check or money order made out to Clarion Corporation of America to:
Factory Service Center
Attention: Customer Service
661 W. Redondo Beach Blvd.
Gardena, CA 90247-4201
The cost is $85.00 per remanufactured speaker assembly
3. Clarion will send out an exchange (remanufactured) unit to the dealer.
4. Install the remanufactured speaker assembly.
Call Clarion's customer service at 1-800-347-8667 with any questions concerning Bose speaker exchanges.
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
MikesChevelle
Aug 9, 2015 11:50 AM
