where can i hook up my remote wire for my amp? (in fuse box?)
Old Oct 8, 2003 | 05:54 PM
silvermax2k2's Avatar
i remember hooking up my remote wire into a fuse for my head unit, but now it is not working, so where can i put it? thanks
Chris
Old Oct 8, 2003 | 06:15 PM
Dohcser's Avatar
Your head unit should have a remote output.
Old Oct 8, 2003 | 07:18 PM
i am using the factory bose head unit.
Old Oct 9, 2003 | 03:39 AM
Dohcser's Avatar
Thats ok, I am not sure about the 98 Max's, do you know if it has an external amp?
Old Oct 9, 2003 | 04:11 PM
kgb006's Avatar
Every deck has a remote wire, bose or non bose. i have hooked up remote to the fuse box on my 1998 chevy yukon which worked fine for a year, till i traded in for a max. i also tried to do the same thing on my buddys 4runner wich did not work fine and allmost burned all of his wiring. So to answer your question find the remote wire behind the deck.
Old Oct 9, 2003 | 05:02 PM
isn't there an easier way? i do not feel like taking apart my whole dash again. especialy since i plan to *hopefully* sell my car soon. can't i tap into a fuse in the fuse box?
Chris
Old Oct 11, 2003 | 12:45 AM
jmax
You could tap into an unused fuse in the box and install a switch. But I wouldn't want to tap into anything else because it would suck for that fuse to blow while you are driving down the road. And maybe lose power brakes, headlights, defrost, whatever. You could also install another small fused wire from the battery and Install a switch.
Old Oct 11, 2003 | 01:45 PM
KsuMax's Avatar
Cheesing away...
Taking apart your dash to get to your head unit isn't hard or that time consuming. There is remote wire that should come from your head unit.
Maxie40
Sep 14, 2015 11:28 AM
popdedop
Sep 11, 2015 11:17 AM
conansriver
Sep 11, 2015 10:26 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
intimidator
Sep 5, 2015 07:23 PM
