Wiring amp
Old Oct 14, 2003 | 09:14 PM
Mrfrog840's Avatar
Wiring amp
Where should i put my power cable through the engine compartment to the inside of the car. I cant find any place that it will fit through. Where did you put your power wire through? Im thinking about putting it where the steering column goes through. Thats the only place i can find!
Old Oct 14, 2003 | 09:17 PM
AscendantMax's Avatar
i'd just drilled a hole thru my firewall. i figure it uses less wiring that way, which should help keep voltage drop lower
Old Oct 14, 2003 | 09:28 PM
Mrfrog840's Avatar
Thanks didnt think of that. Ill try it tomorrow
Old Oct 14, 2003 | 09:41 PM
but before you do, make your you don't drill through a cable or whatever important!
Old Oct 14, 2003 | 09:45 PM
Mrfrog840's Avatar
yeah ill drill through engine compartment first just to be sure
Old Oct 15, 2003 | 01:52 PM
mdmartin92's Avatar
Don't drill, you don't have too
I just ran power cable for my amp that I installed and ran it through a grommet that the hood release cable goes through. There is a writeup you can search for about an infinity basslink install that i think a member named tony fernandez posted. It has detailed pics and instructions. The only thing it left out was how to remove the wheel well liner. It is easy to remove, just 3 screws (2 that hold on mud flap and one where liner and body meet (just look can't miss it). There are also two screws that pop in like a door panel holder that you just pop out. It took me about 15 minutes to run the cable from the battery to the trunk.
Marc
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
