VIPER 530T Install?
Old Oct 25, 2003 | 01:25 AM
Drew96I30's Avatar
VIPER 530T Install?
I have a couple Viper 530T's laying around and I plan on putting them in my car once I get a remote start alarm. I was wondering if someone could point me in the direction of some install directions. I don't have the paperwork that came with the modules so I need a little help. Thanks to anyone that can help!!
Old Oct 26, 2003 | 06:18 PM
Supa Lao's Avatar
That the window's module right? If so, I have the paper work at work. I can get it for you if you want.
Old Oct 26, 2003 | 07:36 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
could you send that to me as well, Dex?
Thanks.
Old Oct 26, 2003 | 07:53 PM
Drew96I30's Avatar
yea, thats the one! i really need the directions. you can email em to me at drewhfarrar@aol.com or if it's easier to mail them you can send them to:
Drew Farrar
318 Lake View Way NW
Leesburg, VA 20176
thanks a lot! I'll paypal you a few bucks for your time!
-Drew
Old Oct 27, 2003 | 09:50 AM
Pearl96Max's Avatar
I tend to get a bit irritable
If you guys have a fax machine available, I can also fax the wiring diagrams to ya.
--Don
Old Oct 27, 2003 | 10:06 AM
ny96max's Avatar
...plan on running wires into each door. I did all 4 doors and now have one touch up/down at any window switch in my car
they are one of the best mods that i have done so far.
Ant
Old Oct 27, 2003 | 05:58 PM
Supa Lao's Avatar
Drew, i'll email you the color schematic and I'll send the paper work snail mail to you.
Max5speed, I can do the same for you too. I just have to wait til I get back to work tomorrow morning
Old Oct 27, 2003 | 06:09 PM
Drew96I30's Avatar
great, thanks!
Old Oct 28, 2003 | 05:25 PM
Supa Lao's Avatar
Harness 1 (heavy gauge wire):
1. violet - ground path motor #1
2. green - down, motor #1
3. blue - up, motor #1
4. red - (+) 12v constant, 20a fused
5. black (-) chassis ground
6. violet/black - ground path, motor #2
7. green/black - down, motor #2
8. blue/black - up, motor #2
Harness 2 (light guage wire):
1. brown - up, switch #1
2. white - down, switch #1
3. red/white - (-) auxiliary input
4. orange - (-) ground when armed
5. gray (-) output during activation
6. brown/black - up switch #2
7. white/black - down switch #2
Harness 1:
1. violet: this wire provides the ground path for the side 1 motor. Connect this wire to a paint-free surface on the vehicle chassis. Use a factory bolt if possible
2. green: Cut the down (side 1) wire at the switch and connect this wire to th motor side of the down wire.
3. blue: Cut the up (side 1) wire at the switch and connect this wire to the motor side of the up wire
4. red: Constant 12v power source
5. black: ground
6. violet/black: This wire provides the ground path for the side 2 motor. Connect this wire to a paint-free surface on the vehicle
7. green/black: cut the down (side 2) wire at the switch and connect this wire to the motor side of the down wire
8. blue/black: cut the up (side 2) wire at the switch and connect this wire to the motor side of the up wire.
Harness 2:
1. brown: Connect this wire to the switch side of the up wire (side 1)
2. white: Connect this wire to the switch side of the down wire (side 1)
3. red/white: Connect this wire to the a (-) validity channel output of the security system.
4. orange: Connect this wire to the (-) ground-when-armed output of the security system. This wire can also be connected to an auxiliary channel of the security system to send the windows up/
5. gray: connect this wire to optional relay to bypass sensors which may trigger the security system during operation. This wire continues (-) ground for 5 sec. after the window motors have stopped.
6. brown/black: Connect this wire to the switch side of the up wire (side 2)
7. white/black: Connect this wire to the switch side of the down wire (side 2)
Old Oct 29, 2003 | 06:59 PM
Supa Lao's Avatar
Drew, I mailed it out this morning
Old Oct 29, 2003 | 09:28 PM
Drew96I30's Avatar
thanks, you da man! whats ur email address for paypal?
Old Oct 29, 2003 | 09:36 PM
Pearl96Max's Avatar
O yea, I faxed it to ya this mornin' Did ya get it?
-_Don
Old Oct 29, 2003 | 09:56 PM
Drew96I30's Avatar
yea, i sure did! thanks a lot Don!! Since I am doing all 4 windows I want to go ahead and do the sunroof as well. I was planning on using a pulse timer (DEI 528T) to do this. Would u recommend otherwise? Also is there a way to set it up so that I can roll down all the windows and open the sunroof with only one trigger?
Old Oct 30, 2003 | 06:32 AM
Supa Lao's Avatar
no need to paypal me. just helping out
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
