light weight batts and audio performance
Old Nov 2, 2003 | 09:13 PM
mad-max98's Avatar
what's the lightest weight battery that will not affect audio performance i heard about optima, odyssey but i noticed you get either light weight or high performance , i have jl 300/4 , jl 500/1 and 2 rockford hx'2 subs thnx
Old Nov 3, 2003 | 10:12 AM
foetray's Avatar
I would get A Optima yello top because it can take the discharging and charging a stereo causes. But you could get a decent lightweight battery and use an Xtatic 300 or 400 batcap for capacitance.
Old Nov 4, 2003 | 03:23 AM
mad-max98's Avatar
ok what do you think if i get odyssey 13lb and a capacitor , will that do the trick and what kind of caps will be best
Old Nov 5, 2003 | 01:53 AM
foetray's Avatar
It is reccomended that you have 1 farad of capacitance for every thosand watts of power you have. If both amps are stereo, thats 800 watts=1 farad. But waht would be the fun of having HX2's if you didn't mono bridge, right? In that case the JL is in theory putting out 1000 watts + 300=1300=1.5 farads. There is also a company called Xtatic that makes a "Batcap" of different sizes that has a better discharge/charge time than a regular capacitor. Theyre a little more expensive though.
Old Nov 5, 2003 | 02:53 AM
mad-max98's Avatar
ok what about 2 batcap 4oo model and no battery or just one 800 model both setups wiegh about 10-15 lbs
Old Nov 6, 2003 | 01:31 AM
foetray's Avatar
I don't know if a batcap will start or run a car. One battery and a 400 should suffice.
Old Nov 6, 2003 | 01:50 AM
mad-max98's Avatar
[QUOTE=foetray]I don't know if a batcap will start or run a car. One battery and a 400 should suffice.[/QU
well you're missing the whole point of doing that which is weight reduction while keeping audio performance so i'm trying to get rid of the heavy battery
Old Nov 6, 2003 | 02:05 AM
foetray's Avatar
[QUOTE=mad-max98]
I got that, but your options are somewhat limited. I was saying get the lightweight battery and use the 400 for supplemental power.
Old Nov 6, 2003 | 05:13 AM
mad-max98's Avatar
that's one option but its alot of money , what u think of the 8oo by itself i heard its a battery and a cap in the same time and it has 800 cca which is good
Old Nov 7, 2003 | 12:42 AM
foetray's Avatar
I have never seen a batcap start or run a car before. It is more like a battery that acts like a cap. It's designed to recharge from a discharge in 10 seconds. I don't think you'll have a problem starting the car, but runninig lights, A/C, etc. may cause a problem.
vybz05
Dec 10, 2015 07:38 PM
A32goldylocks
Sep 2, 2015 06:39 AM
rhill4193
Aug 31, 2015 08:18 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Slamrod
Aug 10, 2015 12:33 PM
