Show Us Whats In Your Trunk...
Old May 31, 2004 | 11:51 AM
  #321
HitManSE's Avatar
Its like foam/glue. Once you use it you pretty much have to get a new tire. It "should" get you were you need to go but it sucks to change the tire after as well. You have to all but chisel it off the inside of the rim as well. Nasty ****...then again if your tire is flat, your going to get another one anyway so whatever.
Old May 31, 2004 | 04:25 PM
  #322
slickrick's Avatar
hmm. ive thought about taking out the spare/jack to save weight but im not sure if its worth it.
Old May 31, 2004 | 06:52 PM
  #323
HitManSE's Avatar
If you can keep it, then keep it. Unless your some1 who's trunk is somewhat like mine and access to the spare isnt going to be possible. Then its fine to remove it. Just be sure you got AAA gold for free towing
Old May 31, 2004 | 09:40 PM
  #324
Midknight MAXX's Avatar
Originally Posted by fearthegecko
fix-a-flat will destroy your tire.
Destroy is a little dramatic don't you think. I have personally taken one my tires off the rim after fix-a-flat use and it is'nt that much more difficult in the least. Most of it will stay liquid away. If someone else is going to fix always inform them you use it though, it can be very messy.
Old Jun 3, 2004 | 01:30 PM
  #325
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
messy? Try explosive.
Old Jun 4, 2004 | 05:05 AM
  #326
ny96max's Avatar
nothing special:
Ant
Old Jun 4, 2004 | 05:11 AM
  #327
MacAlert's Avatar
Who made that enclosure? That looks nice and you still have a usable trunk. I think I might have to dump my sub box and do that.
Old Jun 4, 2004 | 02:35 PM
  #328
ShRapNeR's Avatar
here is what will be going in my trunk tomorrow.
ill post pics when done.
Old Jun 4, 2004 | 02:36 PM
  #329
ShRapNeR's Avatar
Originally Posted by ny96max
nothing special:
Ant
for some reason those links dont work for me
Old Jun 4, 2004 | 05:11 PM
  #330
HitManSE's Avatar
Thats a 15 you got there right?
Tell me your going to port it
Nice amp too, make sure you upgrade you elec system, that thing sucks some serious juice. You know, big 3, ect... im sure you need no explintaton.
Old Jun 5, 2004 | 07:35 AM
  #331
ShRapNeR's Avatar
yep its a 15",, box will be 3.75ft^3 @ 35hz.
I was originally going to build it 4cuft, but David from RE gave me the box plans for that sub. So i figured ill just build what it says...
and to be honest... I have absolutely no clue what the big 3 is... would you explain?
i plan on getting a yellow top battery for the time being.. then later on upgrading my alt. and possibly another battery on down the line.
EDIT* do you happen to know when the donations page is going to be back up?
Old Jun 5, 2004 | 01:46 PM
  #332
HitManSE's Avatar
You better run an SSF set at around 38-40hz man, that things gonna be loud as hell but dont go around playing songs like light night tip or anything that dips too low. That limits of that sub are pretty damn close to the Brahma and mine goes into xsus at around 21hz with a 3.5ft^3 box tuned to 28hz fed by 1.2Kw. I run an ssf set at 30hz.
I havnt modeled it up yet, but your going to be near your xmax at about 30hz. Dont quote me on that, but I doubt im far off. Its gonna be loud as hell man, thats for damn sure.
Your on SIN right? you havnt heard that term be4
Upgrade the wires under to hood, or should I say add them.
Add atleast a 4awg wire from your alternator to the battery.
Chassis to battery ground
Chassis to engine ground
Those should be enough to help power flow a bit.
Thats what I did, I have a yellow top...well I have two of them. I have yet to get a 200amp alternator but my voltage holds pretty high. 13.9-14.1 while the car is running & 13.2 with the car off. So im not worried about the alternator just yet. I dont have a cap either.
For this site? well whenever our admin Y2KevSE shows up...if he ever does that is, you can contact him. Him and Jane havnt been around for months though. Not even the mods are able to get a hold of them so, thats still up in the air for now.
Old Jun 5, 2004 | 07:06 PM
  #333
C3nthusiast's Avatar
Cost me:
1 sheet 3/4" MDF precision cut $50
2 2X4 1/2" MDF sheets $10
Black vinyl $12
Glue $8
2 2X4 hardwood sheets $8
JL Audio dual 10" tub $Priceless$
Jig saw blades $5
Old Jun 5, 2004 | 08:00 PM
  #334
maximamaybe's Avatar
Since I just finished my upgrade today I figured I would post.
Replaced my single Kicker Comp VR sub (Actually I blew it so I needed a new sub anyway) with 2 new Elemental Design 12Kxs and build a new box from scratch that would fit perfectly. I am happy with the way it all turned out, but I am glad this project is over.
Let me know what you think.
Old Jun 5, 2004 | 08:15 PM
  #335
HitManSE's Avatar
Damn Nathan, thats a clean install. Looks nice.
C3nthusiast: JL tub? it looks clean though. What model JL's are those W3?
Old Jun 5, 2004 | 08:53 PM
  #336
slickrick's Avatar
have you tried playing with the box location? like moving it to the back of the trunk to see how it sounds? btw it looks great. nice amp choice..got love the look of the nomex cones. what size is the box your using there?
Old Jun 6, 2004 | 05:37 AM
  #337
Thanks for the compliments. This project kicked my a$$. Most of my selft installs have been fairly basic. This is the first box I have built/amp rack I have built myself. Tou have it actually come out the way I wanted it to feels good. I don't plan on moving the box around at all. I honestly needed some trunk space back. The box gives me back some of what I was missing. These subs sound awesome and they are only in 1 cubic foot each.
Old Jun 6, 2004 | 11:09 AM
  #338
Mack Daddy's Avatar
Man you guys have got some big a$$ systems. Nice! Mine pales in comparison but it is good enough for me. Plexi behind armrest, got glow here.
BA RC 620 system up front
Infinity 6502i in rear door
JL Audio 12W3v2 sub
Soundstream E5700 amp
Just need to tidy up a few things and it will look better.
Old Jun 6, 2004 | 11:18 AM
  #339
slickrick's Avatar
looks very nice and clean!
Old Jun 6, 2004 | 03:12 PM
  #340
ShRapNeR's Avatar
ok here's some pics of my trunk,, got it "finish" (although its not) today
Old Jun 6, 2004 | 03:16 PM
  #341
slickrick's Avatar
big box.. how does it sound?
Old Jun 6, 2004 | 03:17 PM
  #342
HitManSE's Avatar
Nice work man, good choice on the brand too
Old Jun 6, 2004 | 03:27 PM
  #343
ShRapNeR's Avatar
its very loud... and sounds very good at doing it....
also..... i could post some vids... but i don't know how to get them on the comp when the camera is not digital anyone care to tell me how?
Old Jun 6, 2004 | 03:28 PM
  #344
AscendantMax's Avatar
the more i read this thread...my hunger for bass increases...
Old Jun 6, 2004 | 03:39 PM
  #345
It's a little bit more involved than digital video, but you'll will need a device/hardware that converts the analog signal to digital. You can get a device like this that plugs into your USB port or an actual PCI card that installs onto the motherboard.
Old Jun 6, 2004 | 05:28 PM
  #346
ShRapNeR's Avatar
ah ok thnx.... ill have to look into that.
Old Jun 8, 2004 | 08:28 PM
  #347
Conrad283's Avatar
I need a truck
Not finished yet, but you get the idea
The window is too big and "off" so I need to re-cut a new piece. But here's the idea. Gonna be sick when it's finished
Old Jun 9, 2004 | 05:25 AM
  #348
MacAlert's Avatar
Looking good Conrad.
Old Jun 9, 2004 | 08:14 AM
  #349
JC96max's Avatar
Old Jun 9, 2004 | 01:08 PM
  #350
R5a7B's Avatar
Looks hot conrad.
Old Jun 9, 2004 | 01:28 PM
  #351
OpTi's Avatar
conrad, what amp is that? It's huge!
Old Jun 9, 2004 | 02:13 PM
  #352
Conrad283's Avatar
I need a truck
Eclipse DA7232 ... The biggest one they have
Old Jun 9, 2004 | 04:22 PM
  #353
Man that's a big amp, what are you going to do cooling wise for the amp? Looks like it can get pretty warm tucked in the wheel well. Looks good!
Old Jun 9, 2004 | 08:51 PM
  #354
Conrad283's Avatar
I need a truck
There's like a 2 inch gap on either side of the floor so the amps can breathe. But nonetheless I have to think up a fan idear
Old Jun 9, 2004 | 09:08 PM
  #355
Pearl96Max's Avatar
I tend to get a bit irritable
No need for fans, the amp is extremely efficent and runs pretty cool. Yes its been in a covered wheelwell before.
Old Jun 10, 2004 | 04:51 AM
  #356
Conrad283's Avatar
I need a truck
My audio guru says I don't need a fan
Old Jun 12, 2004 | 06:25 PM
  #357
Old Jun 15, 2004 | 05:24 AM
  #358
Igor911's Avatar
i'll be posting pics by next weds of my compleated project
Old Jun 17, 2004 | 09:36 AM
  #359
1phtmax's Avatar
me to ill be posting pix soon
Old Jun 18, 2004 | 08:01 PM
  #360
Conrad283's Avatar
I need a truck
Night pics are here:
