wiring amp and sub to factory cd player
I have a '96 ...just got an amp, sub, and wiring kit, but is it true that I need to purchase some converter so that i can have RCA outputs for the factory cd player? let me know please. as a matter of fact any type of info/suggestions is well apprecieated. thanks!
Kevin
Kevin
Kevin
Kevin
Also, I used a test light to find the wire that turns the Bose amp on/off with the radio and I tapped my remote wire into it. Then I just had to ground it and run the power wire to the battery. Easy install.
any other questions, feel free to PM me. Good luck.
Some amps have line level inputs as well as rca. If your amp has them, use them. There are also speaker level input detectors that will give you remote turn on if you don't want to take the radio out, and don't have Bose.
