Need help With Alarm installlation
Old Jan 1, 2004 | 12:35 PM
kyllr's Avatar
Im Install a lcd alarm i bought on ebay and im having a hard time hooking up the parking lights its say in the manual to connect to +12 of parking light i did and nothing happens. Not sure if i need a relay or someting? Also with my power trunk do i need a relay connect it. Also this is the second alarm unit i have tried same deal. By the way its on a 1995 maxima se
Old Jan 1, 2004 | 05:21 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes you need a relay for trunk release, and depending on the unit you have you may need one for lights as well. Trunk needs to see ground to activate and the parking lights on your unit may be a negative output, therefore needing a relay to change to positive.
--Don
Old Jan 2, 2004 | 12:56 AM
kyllr's Avatar
Pearl96Max i think i found the correct wire for the trunk pur/yellow how do i test if its the corect one? And another thing is taht the alarm i have the yellow wire says it need to go to the brake pedal +. But im not using the remote start option im used to connecting the yellow on to the ign on other alarms. Thanks.
Old Jan 3, 2004 | 06:52 PM
blkhawk500's Avatar
kyllr, I'm thinking of buying one of those lcd alarms off ebay also...is it worth it?
Old Jan 3, 2004 | 07:27 PM
mb1's Avatar
mb1
the trunk pin and trunk release both use the purple yellow wire. the release is a high current ground, so you need a relay.
Old Jan 3, 2004 | 08:57 PM
Pearl96Max's Avatar
Actually they dont. Please do NOT connect both wires to the Purple/Yellow. They are the same colors, but by far not the same wire. The trunk release is the larger of the two. As in my previous post yes a relay is required.
For your brake wire...if your not using remote start, then leave it disconnected. Just make sure it is secured and not exposed.
--Don
Old Jan 3, 2004 | 09:43 PM
mb1's Avatar
mb1
--Don
sorry, I was reading off my wire guide and it doesnt specify.
Old Jan 3, 2004 | 10:33 PM
Pearl96Max's Avatar
Its ok, it happens. In Techsoft it does say Purple/yellow on both, so I can see where the confusion would be. For future reference..release and trigger are Never the same wire.
--Don
Old Jan 5, 2004 | 04:45 PM
sadice's Avatar
where can i get the wiring diagram for the alarm system i want to put on myself to save up some money because if i go to a shop it's like 300+ for a decnt alarm so i wnana get one on e-bay or something and install it myself
Old Jan 5, 2004 | 05:37 PM
sadice's Avatar
BTW 97-99 maxima wiring gide for alarm thanx
Old Jan 6, 2004 | 04:26 PM
Pearl96Max's Avatar
Get something reliable and dependable. You dont want to be under your dash every other week trying to fix it.
BTW I only charge $229 to Org members for the Viper 350.
--Don
Old Jan 11, 2004 | 02:30 PM
budha56's Avatar
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|wht/red - wht/pur *6|+ |ignition harness |
| STARTER|blk/yel - blk/wht *6|+ |ignition harness |
| SECOND STARTER|grn/blk - red/blu *6|+ |ignition harness |
| IGNITION|blk/wht - blk/red *6|+ |ignition harness |
| ACCESSORY|red/yel - red *6 |+ |ignition harness |
| SECOND ACCESSORY|blue - wht/blu *6 |+ |ignition harness |
| POWER LOCK|lt. green/red |- |in drivers door at switch |
| POWER UNLOCK|green/yellow *1 |- |in drivers door at switch |
| LOCK MOTOR|brown/white | |in drivers door at switch |
| UNLOCK MOTOR|brown | |in drivers door at switch |
| DISARM DEFEAT|brown | |in passenger door at switch |
| PARKING LIGHTS +|red/green | |steering column |
| HEADLIGHTS|gry/yel(L)blu/blk(R)|+ |steering column |
| DOOR TRIGGER|red/white |- |low in drivers kick |
| TRUNK/HATCH PIN|purple/yellow |- |drivers kick or BCM *2 |
| HOOD PIN|yellow/black |- |BCM *2 |
|TRNK/HTCH RELEASE|purple/yellow |- |low drivers kick *3 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| DISARM NO UNLOCK|*4 | | |
| TACHOMETER|white/green | |ECM *5 |
| BRAKE WIRE|red/green |+ |at brake switch |
| HORN TRIGGER|green/white |- | |
| WIPERS|lt. green/red |- |steering column |
| LF WINDOW UP/DN|blu/red - blu/blk |A |in LF door at switch |
| RF WINDOW UP/DN|blu/red - blu/blk |A |in RF door at switch |
| LR WINDOW UP/DN|blu/red - blu/blk |A |in LR door at switch |
| RR WINDOW UP/DN|blu/red - blu/blk |A |in RR door at switch |
Notes:
*1 Requires a double pulse. *2 The BCM (body control module) is located just below the radio. *3 Must use a relay to interface with this circuit. *4 A single negative pulse to the unlock wire will disarm without unlocking. *5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left. *6 The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
RussMaxManiac
Jan 3, 2001 06:41 AM
RussMaxManiac
Jan 3, 2001 05:40 AM
