Question about power inverter and laptop
Old Jan 2, 2004 | 10:49 AM
OpTi's Avatar
I have a sima m-series 140 watt power inverter. It has a label that says input:12v Nominal DC and output:115v AC. I want to use my laptop in the car. The charger for my laptop has a label on the back that says input:100-240v ~1.4A 50/60Hz and output:19v - 4.74A. Can i use my laptop safely in the car with my power inverter? thanks
Old Jan 4, 2004 | 09:41 AM
xveganxcowboyx's Avatar
This is no expert advice, but I've been using my laptop with a cheap old power inverter and it works fine. i wouldn't worry too much. If the power is way out of whack the batteryshould kick in.
Old Jan 4, 2004 | 11:30 AM
maxu4ia's Avatar
Sounds like you shoud be OK. The only thing you generally have to ensure is that your laptop does not require more than 140 watts. Most laptops don't need more than 75 watts with some larger desktop replacements requiring 90 watts. So you should be OK.
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
AT978
Sep 6, 2015 10:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
