Quieting Trunk rattle
Old Jan 12, 2004 | 11:10 AM
TonyGotSkilz's Avatar
I've got a nice amount of wattage pushing a pretty good kenwood 12 inch sub and i like the sound but i have a good amount of trunk rattle... I'm about to buy a way better audiobahn sub this week and i know my trunk rattle problems about to get way worse....So i'm asking, without dynamat cause i'm about speed first and i don't want all the extra weight, is there anything anyone's done to quiet down the trunk? I was thinking about buying some Rubber blockes like the 2 black ones that are on the trunk already and drilling them in in pieces alittle bigger than the two that are there already so that the trunk close with way less clearance, anyone done this or something similar or better?
Old Jan 12, 2004 | 12:46 PM
Cool J's Avatar
i installed secondskin damplifier in my trunk. 50 sq ft. weights 19lbs and covered my entire trunk with 2 layers in some places. here is a picture of my trunk. copy and paste the link or drag it to the address bar. http://pics.bbzzdd.com/users/Cooljt1...skin_trunk.jpg
Old Jan 12, 2004 | 06:38 PM
sk24iam's Avatar
Pic isn't coming up. I'm considering jsut dynomatting under the trunk door and under the rear deck. How much did all that stuff cost?>
Old Jan 12, 2004 | 06:49 PM
00MAXI's Avatar
Double sided tape behind the license plate worked for me thumbs up
Old Jan 13, 2004 | 01:50 AM
OneToughMax's Avatar
can you tell where the rattle is coming from? like 00MAXI posted, there was some rattle from the rear license plate. if you dynamat that it usually helps out a great deal.
Old Jan 14, 2004 | 04:00 PM
yeah i have dynomat behind the license plate...The main rattle seems to be the airspace between the outside of the trunk and the inside... I mean the area behind the "maxima" lettering on the trunk vibrating....if i push on that with my hand the rattling quiets alot, strangly though if i push down on the trunk it doesn't help much only if i push forward
Old Jan 14, 2004 | 04:58 PM
Nismo's Avatar
What I found out was its the key hole mechanism in the trunk lid, there is a rod that connects the keyhole to the latch and thats whats vibrating.
My solution was to tape that rod down so it wont move BUT you will no longer be able to open the trunk with the key but thats what the remote and door trunk pop is for
Old Jan 14, 2004 | 06:28 PM
BLaZin 2k MaX's Avatar
Dynamat Xtreme worked wonders in my car, check out pics on my webpage.
Old Jan 14, 2004 | 08:10 PM
Cool J's Avatar
for my quote to work you need to just cut and paste into the address bar.
http://pics.bbzzdd.com/users/Cooljt1/maxima_secondskin_trunk.jpg
Old Jan 15, 2004 | 09:24 AM
That sounds good to me, cause i can't use my key to open my trunk anyway, never could (shrug) i was thinking of shaing it eventually anyways.... Is that key latch you taped easy to get to?
Old Jan 15, 2004 | 10:16 PM
HitManSE's Avatar
Personally I think 75% of the rattles are coming from the rear deck lid. I still need to apply the second skin on my trunk lid. As far as the license plate goes, I have a peice of box carpeting on the back and I cant tell if its making any noise.
Old Jan 16, 2004 | 02:56 AM
Nismo's Avatar
if you take off the gray plastic liner off the lid you can see the mechanism behind there and reach it pretty easly. I just taped the metal rod thats there because it moves alot which is why its making alot of noise. think theres 2 rods in there
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
