Rear Speakers wont turn on...
Old Jan 25, 2004 | 01:32 PM
GilroyWasHere's Avatar
Alright...Heres the deal. I got my Maxima a new aftermarket Head Unit. I went to turn it on and the The dash lights, tail lights, and rear speakers wouldn't come on. Everything else were ok(Front speakers, Antenna, etc.) So, i took it back apart and saw that the harness had a huge crack/rip right in the middle of it. SO i went to the store, brought a new one and went back home. I reinstalled it and everything else turned on except the rear speakers. I checked all the fuses and they are alright. I checked the fader and balance on the head unit, their alright. I'm now alittle ****ed and dont wont to take it to somewhere.
Does anyone have any ideas, tips, and/or answers to my problem?
Old Jan 25, 2004 | 01:53 PM
Heres a side note: My step dad just tried a Circuit Tester on the speakers and he thinks they're not getting any power.
Old Jan 25, 2004 | 01:57 PM
AscendantMax's Avatar
i would install the old HU and see if the rear speakers would make any sound. double check all connections too.
Old Jan 25, 2004 | 02:15 PM
Well, theres a problem with that....the reason i got a new head unit because my brother(thats who i bought it from) took his old head unit with him when he sold it to me. I called him and he said that they worked great when he had it. And i did check my wiring and everything is connected.
Old Jan 25, 2004 | 03:00 PM
slickrick's Avatar
check to make sure you did not accidentally cut the speaker wire anywhere.
Old Jan 25, 2004 | 03:11 PM
On the speaker itself or in the wire harness?
Old Jan 25, 2004 | 03:13 PM
guess he means the harness, but it won't hurt to check both
Old Jan 25, 2004 | 03:27 PM
Checked the harness and those wires are alright....Going back in to check speakers.
Old Jan 25, 2004 | 03:31 PM
slickrick's Avatar
just make sure no wires are touching whatsoever while your at it.
Old Jan 25, 2004 | 05:38 PM
ny96max's Avatar
what brand headunit did you install?
i know on certain model PIoneers there is an option to cut the rear speakers off inorder to have sub controls active... that may be your problem. Either that or you have a speaker in the back that is grounding out possibly.
Ant
Old Jan 25, 2004 | 06:45 PM
I have an Awia Head Unit and no Subs...
Old Jan 25, 2004 | 07:46 PM
None of the wires were touching....
What now?
Old Jan 26, 2004 | 09:01 AM
twotone's Avatar
Igor911 says that u need to connect the remote amp turn on wire in order to get those back speakers to power up
Old Jan 26, 2004 | 03:07 PM
And where would i connect that at? There wasn't a wire to connect that to. I'll check again but i didn't see one.
Old Jan 26, 2004 | 03:31 PM
Took the Head Unit back out and checked again. The only wires that were not used were the Illumination, AMP on, and Dimmer wires. Those were from the Nissan Harness. On the Aiwa harness, all the wires were used. There was no place to even connect it to. Any suggestions?
EDIT: Should i splice that wire to another one?
Old Jan 26, 2004 | 04:50 PM
Well....Problem solved....Kinda. I looked at my harness and took the wire that powered the power antenna and connected it to the AMP on wire. When that happened, the rear speakers came on but now i can't use my antenna. Any way i can use both?
Old Jan 26, 2004 | 04:58 PM
rcy's Avatar
rcy
Check here http://www.geocities.com/craigbrace/ It might give you some ideas. Look under the 'how to' section. It might have something to do with the factory amp in the trunk.
Old Jan 26, 2004 | 05:03 PM
Been there, done that. I can get my rear speakers to work but i would have to sacrifice the use of my power antenna. Can i just use the same wire to power both?
Old Jan 26, 2004 | 06:27 PM
slickrick's Avatar
for my car i need a nissan diversity antenna which plugged into my antenna and then plugged into my new h/u. but i could be wrong for your car.
Old Jan 27, 2004 | 10:13 AM
::shrugs::
I don't know...well, i took it out for a test run and the attenna doesn't seem like it was effected other then not going up and down.
Thanks for all of your info and tips guys, It helped alot.
::gets ready for next project.::
Time for some new speakers!
::looks at his old ones.::
Matt93SE
May 24, 2019 02:58 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
