LEDs to come on with switches
Old Jan 29, 2004 | 01:46 AM
phillysmoswantd's Avatar
i have a steel toggle switch to turn on my amp, and i was wondering if there was a way to connect an led to the switch so that it comes on when the switch is on? i dont want to go out and buy a switch with an led light already on it, and figured it would be useful so that i wont leave the amp on, thanks
Old Jan 29, 2004 | 02:40 AM
Nismo's Avatar
buy an led with correct resistors, wire negative to ground and positive to the switch.
BTW why do you have the amp on a toggle switch anyways??
Old Jan 29, 2004 | 03:57 AM
reygarcia's Avatar
Loved by MrGone longtime
sometimes the bass gets to be too much and just wants to turn it off. I have had my amp hooked up to a rocker switch for over about 2 years and haven't had any problems.
Old Jan 29, 2004 | 09:42 AM
my toggle switch has a ground, acc and power, remote wire goes on acc and power, ground to ground, where would the led be connected to
Old Jan 29, 2004 | 09:49 AM
friendhasmax's Avatar
connect the correct resistor (about 470 ohms) to the positive connection on the LED...then connect that to the part of the switch which is controlled by the switch (no pwer when switch is off, power when switch is on) and then ground the negative part of the LED
Old Jan 29, 2004 | 10:43 AM
Maxima-2's Avatar
hook the led to the ACC. that way when your amp gets power so will the LED.
AaronL
Aug 8, 2020 10:31 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
lrb6805
Sep 24, 2015 05:03 PM
