R+R Rear Deck Speakers - Non Bose System
http://carstereohelp.com/stereoremovalNisMaxRSpk.htm
Edit:Never mind it doesn't tell you, it should though. Sorry don't know. But that site is really helpful.
1. remove seat bottom. they pull right out. there are two tabs that holds it down to the frame of the car. the tabs are located near the door area and about 5 inches in. just lift the seat up a little on the edge and you'll see it. IT WILL BE HARD TO PULL UP THE FIRST TIME.
2. remove seat back. there are four 10mm bolts that needs to come out. there are two on each bottom corner. you'll see these after you removed the seat bottom. the other two are located behind the arm rest. it should be covered by these black circle tabs, after you move the bolts, lift the backrest straight up. it'll take some force but it will come off. it's held on by 4 tabs, similar to the seat bottom.
3. after the backseat is out of the way, remove the 3rd brake light (remove plastic housing, then the unit itself). then remove the rear deck, which is held down by small tabs. after that you should be able to get to your speakers.
jskirwin
06-08-2016 08:49 AM
