amplifier power then not
Old Feb 11, 2004 | 05:37 PM
Grisadiche's Avatar
i have a jbl amp, and i recently had a friends box hooked up to it to make sure his subs worked, which they did..........then he disconnected the wires and there was a spark, and now my amp is acting really weird. its got a red light which signifies a problem, and a green light which means its working fine.......the red light is on, but the green light comes on dimly then goes all the way on and my subs work for about 1 second, then the green goes away again. any ideas on what happened??
Old Feb 11, 2004 | 06:14 PM
slickrick's Avatar
if you have your manual it shows troubleshoting techniques on the amp? which amp is it?
Old Feb 12, 2004 | 03:11 AM
Grisadiche's Avatar
its the p180.2.............i downloaded the manual for it, and what its doing is not in the manual, so i don't really know whats going on with it.
Old Feb 12, 2004 | 05:55 AM
Supa Lao's Avatar
Did you check the fuses on the amp and on the power wire. I would say pull them out and look at it closely.
Old Feb 12, 2004 | 09:02 AM
C MAX's Avatar
you tripped the overload switch.. usually it resets itself after you turn off the power for a few minutes.. if not..your still tripping it..check your screws that screw down the speaker wires.. i bet your have the screws touching one of the other channels your grounding it out..make sure nothing touches each other.. the spark i wouldn't worry about if you have the right fuses it would short out before any damage...
Old Feb 16, 2004 | 05:38 AM
Grisadiche's Avatar
thats what the problem was, the ends of two of the speaker wires were just touching......i moved them around a bit, no longer touching.........got bass again, thanks
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
