backseat arm rest question
Old Mar 12, 2001 | 06:47 PM
rambo91145's Avatar
i have a 94 GXE and was thinking about putting something behind the armrest. i was thinking cut out the cardboard,etc a replace it with osb,presswood,or somthin, carpet it, and put in 2 6 1/2s or bass ports or mount a small amp with accent lights around it. has anyone seen anything like this? do you think it will work? tell me what u think...
Old Mar 12, 2001 | 10:16 PM
Nismo's Avatar
yeah I have my amp there facing you when u open the arm rest. I did put a neon there over the amp but later took it out cause I already had neons in the back and it was bright enough
Old Mar 12, 2001 | 11:12 PM
Jon Little's Avatar
i cut out the cardboard and made it a port for my sub
Check it out on my site
Old Mar 13, 2001 | 05:26 PM
rambo91145's Avatar
jon, like the box, but i dont want just a big square hole, what i meant by ports, were 1 or 2 actual 2 or 3 in. ports mounted there. i dont know if it would help on bass.....just an idea nismo: was this hard, how did it look, and how did you set it up? thanks guys
Old Mar 13, 2001 | 06:26 PM
Jon Little's Avatar
if you are going that route, i would replace the stock card board with something with more stablity.
Old Mar 13, 2001 | 08:49 PM
rambo91145's Avatar
ya, as i said in my first post i was going to use osb,plywood, something similar and put sub box carpet on it and mount whatever to it . jon: wasnt it hard to seal the chamber you made in your trunk?
Old Mar 13, 2001 | 11:08 PM
Jon Little's Avatar
It is not completly sealed yet. I cut the board to fit tight enough that i had to hammer it in there, the subs are in their own indepent boxes and a little gap where the spare tire well is, i plan on replacing it with another MDF board.
For better sound quality use MDF board and not plywood. Plywood allows air to get in to it. Just my $.02
Old Mar 13, 2001 | 11:44 PM
SWEETSOUND2001's Avatar
muahahaha
Old Mar 18, 2001 | 12:29 AM
Nismo's Avatar
not hard at all. I screwed the amp to a wood board and had it put up against the back facing the hole. The neon was also screwed to the board right above the amp so you cant see it so only the light shows through. I did have to solder another 6 feet of wore to the neon to reach the front of the car though. Ill try to get pictures once I get them out of my digital camera.
Old Mar 18, 2001 | 08:35 PM
rambo91145's Avatar
cool nismo, cant wait to see the pics cause this is exactly what i was thinking about doing so now i will be able to see what it looks like. do you think it looks good? what does everyone think of my other idea of mounting 1 6 1/2 or maybe 2 4's and a bass port? would this work? any imput appreciated....
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Starrider
Dec 18, 2015 04:43 AM
pears
Sep 18, 2015 05:25 AM
Bonka
Sep 14, 2015 11:18 PM
