New Amp Wont Power Up
Old Mar 6, 2004 | 06:17 PM
99MAX's Avatar
I have 2 amps in my car 1 soundstream refrence 300 that runs 2 - 6.5" alpines
then i smoked the soundstream refrence 500 that powered my 12" solo barick, so to get a cheap sub amp i just purchased an alpine mono channel amp 200 rms supposofly 700 peak, i installed the alpine today and when i turn on the tuner, the sub amp powerd up and kicked the sub nice but the 2 alpine 6.5`s had no sound, i looked at the amp and the red power light was on dim, i swapped fuses in the distribution block for the amps and the 6.51s kicked on but the sub didn`t power, the fuse is not blown, the one that works on boths amps is a 50 the one that didn`t work was a 25 do you think i need 2 50`s any help would be cool
Old Mar 6, 2004 | 09:07 PM
nismos14's Avatar
§è~® f®ÈÄk
get rid of the one that didnt work and try a new one, something is wrong there.
Old Mar 8, 2004 | 12:02 AM
nghtfthlngknvs's Avatar
it sounds like a blown fuse. some times a fuse can be blown and it is really hard to tell. not likely, but it is a possibility. have you tried replacing the bad 25a fuse with a new 25a fuse? if that doesn't work try switching it out for a 50a. these fuses are in the distro block right? not the amps? those should never be changed for different amperage fuses.
Old Mar 8, 2004 | 07:36 AM
twllin's Avatar
have u checked to make sure the remote wire is connected correctly if its not connected right it wont power up
Old Mar 8, 2004 | 07:59 AM
Pearl96Max's Avatar
I tend to get a bit irritable
you may need a relay on the remote lead from the radio.
--Don
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
