Need Amp Help FAST!!
Old Mar 7, 2004 | 11:42 AM
raga55's Avatar
OK so im installing my new amp (us acoustics 2050) I keep getting it to work with the switch in ACC position but when i turn the key the amp goes in to protection mode. Why is it doing this and how can i fix it? BTW my amp for my subs is working fine.
PLEASE HELp!
-RaGa
Old Mar 7, 2004 | 01:55 PM
nismos14's Avatar
§è~® f®ÈÄk
so lets see you turn ur car to accessories position, and the amp is fine, you turn the car on and it goes into protection mode?
Old Mar 7, 2004 | 02:13 PM
kgb006's Avatar
you might have a short somewere, maybe a bad ground
Old Mar 7, 2004 | 02:23 PM
friendhasmax's Avatar
the remote lead from the head unit is wired to the remote input on the amp?
Old Mar 7, 2004 | 02:24 PM
AscendantMax's Avatar
i'd go back and check every connection. make sure the ground is good (no paint on the grounding point)
Old Mar 7, 2004 | 04:13 PM
BLACKonBLACK98's Avatar
Former Vendor
sound like you have the remote power lead hooked to the wrong wire in the harness. very possible that its something more complicated though.
Old Mar 7, 2004 | 06:46 PM
raga55's Avatar
ok heres what i got the amp is in protect mode all the time i rechecked everything its all seems tight and well grounded and the turn on lead is wired correctly im clueless
Old Mar 7, 2004 | 07:25 PM
measure how many volts is the amp receiving when the car is on. there might be a surge of power and the amp goes into protection mode due to that.
Old Mar 7, 2004 | 07:27 PM
raga55's Avatar
would that cause it to stay in protection mode full time cause thats how it is now
Old Mar 7, 2004 | 08:31 PM
vsokolov's Avatar
what kind of head unit do you have
Old Mar 7, 2004 | 08:33 PM
vsokolov's Avatar
its impossible for the amp to work in acc and not work when car is running
Old Mar 8, 2004 | 01:38 PM
raga55's Avatar
hows it impossible? please explain btw its a pioneer hu
Old Mar 8, 2004 | 01:46 PM
Sure it's possible, how else can people listen to their radio with the engine off?
Old Mar 8, 2004 | 02:02 PM
jmax
Depends on how the ignition is wired. Some stuff is designed to be on when in the ACC and start mode, but to go off once the engine is started.
If it is on when the key is in ACC and off when you turn the car on then you either have loose wiring or likely the remote is wired incorrectly.
Old Mar 8, 2004 | 03:32 PM
Former Vendor
what about the gain, i was reading somewhere else and they were saying if your hu has high voltage outs and your amp is designed for low voltage the gain being too far up can send it to protect. not sure if that explains it due to the acc thing though.
Old Mar 8, 2004 | 05:02 PM
jmax
No, that shouldn't be a problem. Most of the protect symptoms are low voltage (or no-voltage) related. And other times when there is a shorted speaker wire.
http://www.kbaudio.com/index.php?x=faqs
Old Mar 8, 2004 | 06:41 PM
Sergey's Avatar
Howdy,
I'm not exactly sure how I got here, but I'm not complaining. This is most likely an indication, that I should write a few more articles.
RaGa, the best way to check your amplifier is to disconnect everything from it except power and ground. Your car can be off for this test, but you'll need at least 10V in your battery. Now, [carefully] run a jumper from the power terminal to the remote turn-on terminal. If the amp still comes up in protection mode, it's most likely broken. Let me know what happens,
Sergey Klypin
www.kbaudio.com
Old Mar 9, 2004 | 09:07 AM
raga55's Avatar
ok sounds good imma try that out most likely friday. Thanks for the tip.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
