thumping noise coming from sub?????
Old Mar 29, 2004 | 06:54 PM
jtm087's Avatar
When I turn my cd players volume all the way down, I hear my sub making a thumping noise and static, when I turn the volume up, I still here it faintly in the back of the music because it makes the beat sound off key. Does anyone know why this is and any solutions???
Old Mar 29, 2004 | 07:00 PM
MannyNJ2k2max's Avatar
Do you think you might have blown the sub?Sounds like it.....
How old is it? Did you check the cone....surround?
Old Mar 29, 2004 | 07:04 PM
jtm087's Avatar
the sub is brand new, and I checked everything seems fine.
Old Mar 29, 2004 | 07:18 PM
Did this just happen out of the blue.....or is this occuring after install? if so u need to go replace your sub...may be damaged
Old Mar 29, 2004 | 08:16 PM
kgb006's Avatar
what kind of sub is it>?
is your box build according to manufacturers specs>?
Old Mar 29, 2004 | 08:28 PM
polishpunk68's Avatar
make sure your gains on the amp aren't set all the way up
Old Mar 29, 2004 | 08:35 PM
AscendantMax's Avatar
How did you run your power and RCA wires?
Old Mar 29, 2004 | 11:11 PM
slickrick's Avatar
yeah check your gains on the amp.
Old Mar 30, 2004 | 04:45 AM
jtm087's Avatar
Its a 10" mtx thunder6000 in the plexiglass viewing box. And I will check the gains on my amp, thank you!
Old Mar 31, 2004 | 10:15 AM
Turbotadpole's Avatar
Did you try reversing the polarity on the power inputs on the back of your box. I had a similar problem. Just try switching the wires around...I know it sounds stupid, but just try it. It's worth a shot.
Peace, TI
Old Apr 1, 2004 | 06:12 AM
thekenone's Avatar
either reversed wires or a short in the amp. happend to a pal of mine. the rca input had a short in it but it would do that outta blue. he opened it a resoldered it. if u can wiggle the rca input on your amp this may be happening to you
pjgreek
Sep 9, 2015 09:30 PM
lux97Max
Sep 4, 2015 05:42 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
