Amp Not Powering
Old Apr 10, 2004 | 11:53 PM
ghettogeek's Avatar
Amp Not Powering
I really need some advice on this. I recently just hooked up my old amp + box. I used the previous wiring so everything should be working right. However, something is up. The power light on my amp does not go on, although there is power going to the amp. Needless to say, my subs aren't working. The only thing I did differently was not hooking up the remote connection. I don't even know what it is, it's labeled "REM". This wouldn't have anything to do with the power light though. I checked both fuses, the one running to my battery and the one on my amp itself. They both seem to be fine. Can anyone tell me what I might be doing wrong? I have a 300w 2 channel coustic amp hooked up to 2 600w subs. It worked just before I took it out. I just don't get it. Thanks!
Old Apr 11, 2004 | 04:26 AM
LeX's Avatar
LeX
Nissan by Nature
you answered your own question.
The REM cord tells the amp to turn on!
you run it from the headunit to the amp, so when you turn the HU on it turns the amp on, and when you turn the HU off it turns the amp off.
That's likely your problem!
-Alex
Old Apr 11, 2004 | 08:52 AM
ghettogeek's Avatar
-Alex
lol...who would have thought that little wire would be so important. Now I know! I'm going to try that out and let you know. Thanks!
Old Apr 11, 2004 | 04:37 PM
ghettogeek's Avatar
Problem is fixed! Thanks!
Old Apr 11, 2004 | 06:44 PM
LeX's Avatar
LeX
Nissan by Nature
anytime
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
