Sound deadening
Sound deadening
Wanna do this to the max, but i know its gonna add weight, Which is not a good thing. But i want to reduce road noise for the system. Whats the ballpark range in wieght that i am gonna add to the max if I do just the front two doors and trunk?
Im not sure but dynamat is heavy stuff. heres what i found on there website. Try researching alitte man..
4" x 10" Dynamat Xtreme
Coverage: 0.28 ft2 (0.03 m2)
Weight: 0.13 pounds (0.06 kg)
Dimensions: 4" x 10" (100mm x 254mm)
See, it will all add some weight.
I use Raam Matt, It is ticker, more flexible, and stickier then Dynamat and 5 times less expensive.
In doors use also metal brackets (corners) from one side of the door to the other (inside the door) so the metal doesn't vibrate.
I would install midbasses in floors. my next project
Where a good place to get some Raam Matt? I did a google search on it and got some results.
Dynamat Extreme works great, it is lighter than the original and is suppoed to work 4x's better. I did my trunk with the Original and had to use a heat gun. I did my front doors with the Extreme, and the roller was all I needed.
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
