Best Amp for 2 Kicker 12 inch Solobarics 2 ohm
Could someone please guide me which amp should i buy to power up 2 S12L7. They are 2 ohm Each.
I am quite illiterate when it comes to this so any help would be great. Am I looking for a D class amp ? I was looking at kicker mono amp D class. Would that be good ? Please Help thank you.
Specifications:
Model: S12L7 2 ohm
Dual 4-ohm Voice Coils
Frequency Response: 20-100 Hz
Power Handling: 750 watts RMS
Peak Power Handling: 1,500 watts
Sensitivity: 87.4 dB
Top-mount Depth: 6-13/16"
Sealed box Volume: 0.88-2.0 cubic feet
Ported box Volume: 1.75-3.25 cubic feet
Specifications:
Model: S12L7 2 ohm
yes it will but you will have to run it at 1 ohm or 4 ohms. you probably should ge ta subsonic filter if you run the jbl amp because it does not have one. id probably look into another amp that has one with it. a pg tantrum 1200.1 i believe puts out alot of power but also drains your electrical system too.
jmlee44
10-02-2022 02:13 PM
