anyone with a apline 9815........ wtf!
Old May 16, 2004 | 10:14 PM
RI-Max's Avatar
ok i love this radio but how in the hell do u adjust the bass and trebble?????? i read the book and and like 4-5 other have and their lost 2. says nothing about adjust bass/trebble. any know how?
thanx. jeff
my setup
-Alpine (CDA9815)
-JL Audio Componets 6.5 (xr650csi)
-JL audio 6.5 (TR650-cxi)
-JL 300/4 amp
-Moster cable RCA
-Moster cable 4 gauge power wire
Old May 17, 2004 | 02:06 PM
nismos14's Avatar
§è~® f®ÈÄk
My guess is, you have to go into the parametric EQ probably, i tried to DL the pdf off the site to see how it works, but it wouldnt work for me.
Old May 21, 2004 | 10:10 AM
mitch33x's Avatar
the parametric EQ adjusts the levels
Old May 21, 2004 | 10:39 AM
slickrick's Avatar
there is no "bass and treble" function on the 9815. you just got into the eq mode.
Old May 21, 2004 | 10:44 AM
Mack Daddy's Avatar
yeah I have a 9830 and I searched the whole owners manual and nothing. Only eq setting. Weird
Old May 30, 2004 | 09:10 AM
ABS's Avatar
ABS
thanx. jeff
my setup
-Alpine (CDA9815)
-JL 300/4 amp
-Moster cable RCA
I have a 9813 which is very similar to the feature set of the 9815. You've probably figured this out already, but you need to go into manual configuration of the parametric EQ to make the changes you mentioned. To do this, you should hit the EQ button 1x, wait for the factory EQ preset modes to startup, then press and hold the parametric EQ button for about 2-3 seconds, until the custom mode starts up. Once in custom mode, you can select specific frequences (80-120 hz would be good for bass), gains +/- 6 and bandwidth 1-3 (1 is wide 3 is narrow), you may also save your settings by pressing and holding one of the numbered preset buttons. I hope this helps!
Old May 30, 2004 | 09:29 AM
RI-Max's Avatar
yup i found how 2 use it lol it kinda sucks in a way tho. but o well i like the blue buttons lol.
Old May 31, 2004 | 05:59 AM
ABS's Avatar
ABS
I agree. Alpine should have provided a way to get into the custom EQ settings with a single button press instead of two and a wait on the second . . . Oh well.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
