Bose on gone BAD......................?
Old May 27, 2004 | 06:21 AM
BLACKICE99's Avatar
I have the bose system in my 99 max and it has (err ,and ejects the cd) on the display when i play my cds....it used to do it once in a while, now its all the time.i bought a dry cleaner and nothing.
anybody had this happen?
can i just replace it with a aftermarket radio?( i heard speakers wont work)
thanks
Old May 27, 2004 | 06:52 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Very common with the Bose radios. Yes an aftermarket radio will work and play fine through the speakers.
--Don
Old May 27, 2004 | 08:03 AM
Jay93SE's Avatar
Don't you need an adapter to convert the screwy 1ohm impedance of the Bose to 4-8ohm's? Or is that just a 3/4 gen thing?
Old May 27, 2004 | 09:13 AM
BLACKICE99's Avatar
thanks for the reply don
Im gonna check out circuit city and have them install it.
Old May 27, 2004 | 09:38 AM
Pearl96Max's Avatar
No an adaptor isnt needed. Its also not a 3/4 gen thing. None of the Maximas "need" and adaptor. The Bose HU provides a signal sent to the amps similiar to that of RCA preouts of an aftermarket HU. Thus only needing to splice female RCA leads to the speakers leads of the factory wiring then plug them into your RCA preout section of your aftermarket HU.
--Don
Old May 27, 2004 | 10:38 AM
DMad8724's Avatar
I don't see why all these new max buyers keep getting Bose...paying more money for things that have already been proven to go wrong in other generations...STOP GETTING BOSE!
Old May 27, 2004 | 11:06 AM
BLACKICE99's Avatar
hey pearlmax96
I went to curcuit city they want $55 just to rewire it not to mention additional b.s.
i can do it myself.....i used to put radios in cars...i have an amp installed already and it has the adapter piece to make rca in the bose....i wont need that anymore because of the aftermarket radio right?
my question is it simple to put the radio in and rewire it?how long you think it will take?
thanks
Old May 27, 2004 | 11:20 AM
Pearl96Max's Avatar
People are getting it A: because they bought the car used and it wasnt an option to not take it or B: becuase its part of a package and not a single optional item. I have BLose in my '03 Altima and only because I wanted leather with heat,etc...
--Don
Old May 27, 2004 | 11:22 AM
Pearl96Max's Avatar
Originally Posted by BLACKICE99
hey pearlmax96
thanks
No you wont need the adaptor anymore. It is a generally simple job to do especially considering your not using the factory amp anymore, IF your aftermarket amp is running your interior speakers. If its not then still a simple install and you would need to use the splicing of female RCA leads route.
--Don
Old May 27, 2004 | 11:28 AM
BLACKICE99's Avatar
--Don
(splicing of female RCA leads route)
what do you mean?......do they have a write-up on this?
Old May 27, 2004 | 11:36 AM
njmodi's Avatar
Do I get a tax break?
Yes - whats this about not needing an adapter anymore... is this because the newer aftermarket HU's have preamp outs? - so you can continue to use the existing speakers amps that are part of the bose setup?
Don/Pearl96Max please elaborate - you have some very valuable knowledge!
Old May 27, 2004 | 06:06 PM
Pearl96Max's Avatar
BLACKICE and njmodi...it is nothing new and adaptors were never actually "needed". Just another item for retailers to gain a profit on. I do not like to do my business that way.
As far as the actually connections..Simply put when you use your aftermarket wiring harness to install the radio connect the speakers leads to RCA ends instead of directly to the aftermarket radio. The plug them into the preout section of the headunit. Done.
--Don
Old May 27, 2004 | 06:24 PM
Pearl96Max's Avatar
EDIT: above I posted FEMALE RCA leads, I meant MALE. Sorry for the confusion.
--Don
Old May 28, 2004 | 05:45 AM
njmodi's Avatar
Don, thanks for the clarification.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
