2K2 Bose Sub
Old May 31, 2004 | 06:15 AM
ABS's Avatar
ABS
2K2 Bose Sub
Well, my upgrades for an amp, hu and front speakers are finally completed. I now have to determine what I'm going to do about a sub. I am leaning toward a "free-air" solution mounted on the rear deck because I really don't want a big heavy box in my trunk and because I'd like to be able to blend the woofer into the rest of the system a little better. I expect that the "free-air" design will do that. As a first step, I was considering one of two options, either wiring a signal from my HU straight into the existing amp on the Bose sub or bypassing the existing Bose sub amp and running my own power amp to it. Then, depending upon the results/performance, I could upgrade to an aftermarket woofer which I would custom mount on the rear deck.
So, before I get started, I'd like to solicit input from anyone who might have performed these sorts of tests on the OEM Bose subwoofer. I'm really interested in whether or not it can sound better than the stock Bose system did just by using an aftermarket HU signal and/or by using an aftermarket amp with it. Thanks!
Old May 31, 2004 | 08:01 AM
Clif13's Avatar
I want to know the same thing....I want to replace the sub in my 2000. Ill be watching
Old May 31, 2004 | 12:31 PM
MacAlert's Avatar
Running an aftermarket HU with the Bose amp will work. However, don't expect great sound. Actually, don't expect ANY improvements. Sound will get worse then stock. I had an Eclipse HU with the stock Blose system and it sounded like garbage. No bass at all. I ripped it all out today and put in all new components. Sound is excellent now. Do the work right the first time, change out all speakers and wiring.
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
