help please. how can i install an after market headunit in my 99 max with BOSE..
Old May 31, 2004 | 12:53 PM
Zack342's Avatar
i would like to install an aftermarket headuint in my 99 max with BOSE but i can't affod to replace all the speakers right now. can someon direct me on what i may need to install a aftermaket headunit in my max with replacing the speakers. i know its call an interface of some sort. my question is
where can i get one
how hard is it to install
and how well does it work.
the reason i am removing the bose is because i would like to install a headuint which plays mp3s....
please help if you have done this or if you know how this can be accomplished.
Old May 31, 2004 | 02:09 PM
gtr_rider's Avatar
192.168.1.1
You can purchase the converter from Bestbuy, it comes with a wiring chart so that you know what is what. It works very good, only problem Ive found is a slight poping sound when changing stations and what not. NO biggy.
I have a picture of how I wired it, here:
http://forums.maxima.org/showthread.php?t=312713
Old Jun 10, 2004 | 06:00 AM
DonSupreme's Avatar
How much did the converter cost, and does it come with a remote start cable (for powering up external AMP for subs)?
Additionally, what is your opinion on the quality of the sound from the existing Bose speaker after swapping the HU. I have seen comments that suggest that the new HU really improves the sound from the existing bose speakers. I have an amp and subwoofer, and I am not looking to build a super system, just something cleaner, and with some thump.
With that said I am trying to decide whether or not i should replace the HU, or just get the adapter for my sub.
I usually turn the bass to the in car speakers to a minimum and let the Sub do all the bass work. This usually allows the in car speakers to do a better job at louder volumes.
Well what do you guys think?
Old Jun 10, 2004 | 08:56 AM
Teameyekon's Avatar
www.peripheralelectronics.com
They have it there. Its just an audio interface
Old Jun 10, 2004 | 10:26 AM
Pearl96Max's Avatar
I tend to get a bit irritable
No interface is even needed. This is asked about once a week. Just add male RCA jacks to your factory speaker leads behind the radio. Then plug them into then preouts of the aftermarket HU. Power the stock amp with the remote lead from then HU and your done.
--Don
Old Jun 11, 2004 | 09:37 PM
DonSupreme's Avatar
To the factory speaker leads? Aren't all the speakers being used? How would someone just ADD the rca jacks to it?
Old Jun 12, 2004 | 11:23 AM
Pearl96Max's Avatar
Adding is in ADDition to something. SO it would be irrelevant that all speakers are being used. To add the RCA jacks would just require splicing into the wires.
--Don
Old Jun 12, 2004 | 12:46 PM
SuperChris's Avatar
Infiniti 35 Double G's
i have a 99, and replaced the Bose HU long before I put in new speakers. you don't need an interface....the speakers should work with the new HU. the "fun" part will be removing the Bose from the stock brackets...those screws are a biznitch to get out.
good luck...
Old Jun 12, 2004 | 04:39 PM
Maxima 504's Avatar
yeah i did the same thing also without the interface.. glad i did and the stock bose speakers work very well with my alpine HU.
dank4us
34
Jun 10, 2024 03:45 AM
VQ'ed
69
Aug 27, 2020 12:29 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
Abdelrhman
Aug 17, 2015 12:16 PM
MikesChevelle
Aug 10, 2015 11:21 AM
