Attaching an Amp to back seat of 5th gen
Old Jun 11, 2004 | 10:20 AM
nadeemp8's Avatar
Has anyone attached an amp to the back seat of a 5th gen Max? I have a large amp for my sub which I need to attach but since it is so heavy I can't screw it in directly to the seat or it falls off. Anyone have some tips or tricks on how to do this?
Old Jun 11, 2004 | 11:43 AM
kgb006's Avatar
i made a fire wall behind the back seat and mounted my amps to it.
Old Jun 12, 2004 | 06:21 AM
adamlee2001GXE's Avatar
when I had my system installed, they built an amp rack for my amps. It looks very nice and blends in to the carpet of the trunk.
Old Jun 12, 2004 | 11:00 AM
Slow Moe's Avatar
Sounds pretty cool, can we see some pics of your set up?
Old Jun 12, 2004 | 11:39 AM
I would, but I dont know how to post them. I havent taken the plunge and made my car domain site, assuming that's the only way to do it?
Old Jun 12, 2004 | 03:07 PM
Kojiro_FtT's Avatar
There is sheet metal in there if you search enough. Mine are just screwed into the sheet metal.
Old Jun 15, 2004 | 04:31 PM
mdmartin92's Avatar
I did it with no problems but did it a little different. I removed the cloth seatback cover with a door trim removal tool. I double nutted 10/32" bolts through the cloth cover so that I could secure the amp with wing nuts (makes it easy to take amp out if ever needed). I then put the cloth cover back on the seatback but also secured it with sheet metal screws into the metal frame in the seats. My amp has been like this for over a year with no problems driving through huge potholes in Boston every day.
Old Jun 15, 2004 | 06:02 PM
nadeemp8's Avatar
That sounds like it holds up really well...I'm thinking about putting in a sheet of plywood as a floor and making an amp rack on it and a custom encolsure for my subs. I'm still looking at diff setups but thanks for your input, I may end up trying something like that too.
Old Jul 11, 2004 | 09:59 PM
myktek's Avatar
it's an ok location to mount it, i had 2 mounted to the backseats...worked fine w/o any issues
Old Jul 11, 2004 | 10:28 PM
MIXXMAX's Avatar
I have one of my amps mounted on the back seat. Check out my homepage for pics!
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
doctorpullit
Aug 20, 2015 05:15 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
