Upgrade 5th Gen Free Air Sub
Old Jun 15, 2004 | 08:26 PM
ABS's Avatar
ABS
I'm looking for upgrade options for the Bose free air 8" sub on my rear deck. I'm not sure what sizes will fit. I do not plan to build/use an enclosure. Has anyone had experience with this who can recommend a good sub for me? I was considering a Vifa M21 with a Qts. around .66. I'm also interested to know how big I can go, 10"? 12"? Thanks!
Old Jul 11, 2004 | 09:57 PM
myktek's Avatar
JL makes a 8" free air sub.... that should fit fine where the bose sub would go....
Old Jul 12, 2004 | 10:57 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i was REALLY considering that jl w7 8".....but would that sound good free air??? has anyone done that??? oh and i dont think a 10 or 12 would be good, you'll have to cut out metal and prob make the back stronger cause of all the weight, i you may have to do that anyways for teh JL 8"...
Old Jul 12, 2004 | 01:01 PM
MannyNJ2k2max's Avatar
not too many choices for a free air- most likely the JL is your best bet
Old Jul 12, 2004 | 08:22 PM
myktek's Avatar
the W7 won't sound right...b/c it is built for an enclosure....only option from JL is the 8IB4 which is pretty hard to find....
Old Jul 12, 2004 | 09:28 PM
Maxima112's Avatar
how about another company? any recs?? thanks.
Old Jul 20, 2004 | 07:24 PM
MAX2000JP's Avatar
Can you wire a aftermarket sub to the stock bose amp? A friend of mine told me Kicker makes a sub that should work well in free air applications.
Old Jul 21, 2004 | 12:07 AM
myktek's Avatar
yeah kicker has a few applications that will work w/ the stock bose amp, but i recommend going aftermarket, b/c you'll get more power to the sub...
Old Jul 21, 2004 | 04:08 AM
Tony Fernandes's Avatar
I've heard REALLY good things about Oz Audio free air subs.
Tony
Old Jul 21, 2004 | 06:48 AM
scott_max1's Avatar
kicker makes one free air
Old Jul 21, 2004 | 08:35 AM
MAX2000JP's Avatar
This is the sub my friend recommended
http://www.hookedontronics.com/show_...s.jsp?cid=4354
My bose sub is blown and I need a replacement. He said this sub will work better than the Bose driver and I dont need a amp.
Old Jul 21, 2004 | 08:54 AM
SKYRockerr's Avatar
that sub says it needs a enclouser, where it says free air , it says no..
Old Jul 21, 2004 | 09:09 AM
MAX2000JP's Avatar
He mentioned it wasnt designed as a free air sub, but the specs of it should make it perform well in a free air application.
Old Jul 21, 2004 | 09:21 AM
SKYRockerr's Avatar
Yes , but what about installing a good set of 6.9 speakers in that deck and adding a box with subs in the rear?
Old Jul 21, 2004 | 12:39 PM
scott_max1's Avatar
i done that on my old 2000 max gle didnt work out to good on top of a very bad install. they put in the 6x9s crooked it couldnt fit in there str8 cause of the seat belt box retractors and they put the speakers on top of the carpet making them stick up and look all ugly even if they did a good job installing them it probly still wouldnt look good. u better off with componets in all four doors and if thats not enough then try an other set and make them flush with the carpet so that the grills are level with the carpet. Im thinking if u put a woofer on the rear deck u will get a lot of rattling like i did with just my 6x9s...and then the 6x9s over powered the door speakers in sound, i had to turn down the gian on that amp pushing it so i could hear the fronts to get that all around even sound effect.
Old Jul 21, 2004 | 08:14 PM
Maxima112's Avatar
im tyring a diamond audio 8" free air in a week, ill let you guys know how it sounds....Diamond audio said it would be ok to use this sub free air if i had a subsonic filter for 40 hertz...so i gotta wait for that..
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Dasmith
Aug 25, 2015 10:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
