Need Stereo Help!!
Old Mar 30, 2001 | 05:57 PM
GoLdEn MaX's Avatar
Ok. I have 2 10'' mtx 5000s will a little 250x mtx amp runnin em. So u thinkin now oo thats a small amp i dont know waht would be wrong. But believe it or not the small amp is like drainin my whole car. The headlights are dimmin the interior lights dim, the lights on the cd player actually blink on and off when the subs hit. Also when i make sharp turns or hit the breaks the sub and amp shut off for like a second, also when i leave my fingers on the power windows to roll them all the way down the subs shut off again. Im tryin to figure out what i should do, whether i should get a yellow optima battery or get a capacitor. I would gladly buy a optima but i just got my battery replaced and i dont wanna spend 140 to get another one. So i was wondering if a 1.0 farad cap would solve my problems. Thanks.
Old Mar 30, 2001 | 07:10 PM
94SUPERMAX's Avatar
Did you ground everything right?
Maybe your alternator can't keep up.
I have never heard of such a small amp draining your whole car.
Old Mar 30, 2001 | 07:36 PM
GoLdEn MaX's Avatar
When i got the battery i got a new alternator also about 2 months ago.
Old Apr 5, 2001 | 07:59 AM
CanuckAMP's Avatar
What size power and ground wire did you use to hook this up? What terminations did you use? Where did you take power from? The battery? Where did you ground the amp?
I need to hear more about your install to determine what the problem is. This should not be happening. Also are your subs 4 Ohm or 8 Ohm and are you wiring them to the amp in stereo or bridged mode?
Old Apr 5, 2001 | 01:57 PM
Redmax's Avatar
Redlinemax Owner
Your power wire or speaker wires maybe grounding out or you maybe using too small of wire. are you wired directly to the battery
Old Apr 5, 2001 | 05:46 PM
GoLdEn MaX's Avatar
Thanks guys Prob Fixed
Thanks for all the feedback it turned out to be a loose ground thats y it shut off when i went around turns at high speeds.
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
ivorton23
Sep 28, 2015 09:08 PM
